Under deck cleaning safely
/ Under deck cleaning safely #22
I have found with gator blades I get very little build up of grass on the underside of the deck, perhaps within 2" of each blade hub a buildup and that is it, my deck is the 60". I scrape it off and I am good to go. I do not like to power wash the deck, water and grease hubs and high pressure water does not go well.
Agree, I am not a fan of power washing things like this. I will do a light scrub, with just a normal squirter on the end of the hose. I use two straps and the bucket to lift up the deck so I can hose it off.
/ Under deck cleaning safely #23
Excellent point about using a power washer; The spindles likely don't have water proof caps on them. And the grease WILL get washed out if you're not careful. But - if you're intent on power washing under the deck, I bought a U-shaped section sold by Northern Tool described for washing house gutters.
You could actually make your own section of extension by using a short section of the wand extension and a bending it with a tubing bender. I rarely use my U-shaped extension for washing house gutters, but it certainly is handy for washing the underside of my truck fenders. For the benefit of those that are already raising their eye-brows about me washing under the fenders of my vehicles, I will not describe how I wash the back side of my tires :)
/ Under deck cleaning safely #24
I've noticed this too - the Gator blades don't seem to cause as much buildup.
I use my long trailer ramps - run the tractor half way up. Gets the deck off the ground and at an angle so it's an easier shot with a garden hose. Agree that a pressure washer might be too much.
Z.
Thanks for all the great suggestions. Didn't think pressure washing every week could be possibly bad. Guess I'm little obsessive about cleaning it, just dont want to have to replace deck anytime soon.
/ Under deck cleaning safely #26
Another note, if you hose under the deck, do not do it right after use. Allow it to cool down. If you spray cold water onto a hot spindle it will suck in the water and force the grease out.
/ Under deck cleaning safely #27
Just take 5 minutes to take it off for a good pressure washing. That's the only way you're going to get it all.
/ Under deck cleaning safely #28
Mine comes off after I finish mowing....I don't want to tear it up in the woods. That deck is spendy.
But I do hose mine off after each use...I just hook a couple tie down straps to it lift it with the bucket and the grass comes right off. I am always far enough away incase a strap slipps or snaps...but I doubt it will happen.
Then like I said a normal squirter or the old thumb over the end of the hose is more then enough to get the grass off.
/ Under deck cleaning safely #29
Wow EVERY time you cut grass? This time of year I am cutting grass every 4 days, that would add significant time to cutting grass. My deck is 12 years old, I clean the grass once a year before I put it on for the season. I do not see any unusual wear on the deck.
/ Under deck cleaning safely #30
Wow every 4 days. Heck I am mowing about 10ac each time. That would kill me in fuel costs.
We usually have 3 mowers going and it takes us about 4 hours to do it.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
2022 EZ-GO ELITE...
