Unable to Shift Gears
/ Unable to Shift Gears #1
bungerag
Texas
Massey Ferguson 30B
Hey all. I've got my 1980 MF 30B up and operating again after sitting for 10+ years. Problem now, though, is that I'm suddenly unable to shift into 2nd and 3rd gears. This tractor has 6 speeds (3 on the column, high and low) but for some reason I can only shift between neutral and 1L and 1H.
From the fill cap, I'm able to see the "rails" are lined up correctly, and I can pry it into second and third with a screwdriver just fine. But the shifter just doesn't seem to bump over enough to move the second "rail" in order to engage second and third gear. What am I missing here?
/ Unable to Shift Gears #2
Dirt or rust around the shift lever ball? If so take the shift lever off and clean it out.
/ Unable to Shift Gears #3
Are you sure the clutch isnt stuck?
Being that I can drive and operate the tractor normally with the clutch, I don’t think so. Clutch engages and disengages normally with the engine. Must be the shifter lever
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
School bus (A64194)
School bus (A64194)
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2014 John Deere 650K LGP Crawler Tractor Dozer (A64553)
2014 John Deere...
