Unable to Shift Gears
/ Unable to Shift Gears #1
bungerag
Texas
Massey Ferguson 30B
Hey all. I've got my 1980 MF 30B up and operating again after sitting for 10+ years. Problem now, though, is that I'm suddenly unable to shift into 2nd and 3rd gears. This tractor has 6 speeds (3 on the column, high and low) but for some reason I can only shift between neutral and 1L and 1H.
From the fill cap, I'm able to see the "rails" are lined up correctly, and I can pry it into second and third with a screwdriver just fine. But the shifter just doesn't seem to bump over enough to move the second "rail" in order to engage second and third gear. What am I missing here?
/ Unable to Shift Gears #2
Dirt or rust around the shift lever ball? If so take the shift lever off and clean it out.
/ Unable to Shift Gears #3
Are you sure the clutch isnt stuck?
Being that I can drive and operate the tractor normally with the clutch, I don’t think so. Clutch engages and disengages normally with the engine. Must be the shifter lever
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
2020 Chevrolet Silverado 5500HD Dump Truck, VIN # 1HTKHPVK0LH288017 (A61165)
2020 Chevrolet...
DROP AXLE W/BRAKES (A62131)
DROP AXLE W/BRAKES...
1995 Crosley 20ft. 3 Ton T/A Equipment Trailer (A61568)
1995 Crosley 20ft...
2017 Ford Expedition SUV (A61569)
2017 Ford...
2000 Freightliner FL112 T/A Dump Truck (A61568)
2000 Freightliner...
