unable to post with Explorer
/ unable to post with Explorer #1
radman
Kubota L3710, JD5300, AC D19, IH 806, IH 8950, Ford 8N, Farmal Super M, several others in the past.
With the new TBN format, I can no longer post with Internet Explorer. I get a message saying " user name is too short". What does that mean? I can post using Netscape. Any suggestions? Tried contacting TBN by e-mail but no reply.
/ unable to post with Explorer #2
Which version of internet explorer?
<font color=blue>Tried contacting TBN by e-mail but no reply</font color=blue>
To which address or which method? We usually reply within a day to all support e-mails...
Muhammad;
Tried e-mail address: contact@tractorbynet.com The error message is "username is not the proper length". Any suggestions? I have never had a problem until the new format using Internet explorer.
/ unable to post with Explorer #4
What verson of IE are you on? They are up to 5.5 SP 2 now, and also beta version of 6.0 is out.
You should be at least on 5.5, to make sure it is not an incompatibility issue.
/ unable to post with Explorer #5
1. When you email, what application are you using?
2. Are you using a browser (like IE) to access a web-based mail app (e.g yahoo)? (sounds like it from your description, just want confirmation)
3. When you send the email, does it fail before it sends the email, or is the failure sent back to you as an email message?
/ unable to post with Explorer #6
<font color=blue>beta version of 6.0 is out</font color=blue>
I'm using 6.0.2600; didn't know it was a "beta" version.
/ unable to post with Explorer #7
Bird,
Uh, I guess maybe it is now an open release. I am not sure ANY of MS products get EVER out of BETA!!!!!!
I have been using IE 6.x, and like it, except I had to tweak the "privacy" settings which were too restrictive for many sites in the default setting.
I am using IE version 6. E-mail is through local service provider Alltel. When I send the e-mail, the message seems to fail before it sends the e-mail the message is immediate. Nothing has been changed on my computer in the past 3-4 months. Only TBN has changed. No problems when use netscape. I am not a computer whiz, but I keep believing the problem should be simple.
/ unable to post with Explorer #9
You need to go into internet explorers hidden settings and uncheck all these boxes.
/ unable to post with Explorer #10
Radman,
Well, even though you haven't changed anything, somethings has obviously changed. I'm also using IE 6 (6.0.26 actually), and it's all fine. A lot of other people are using it successfully on TBN as well, so I think that's a false clue.
It sounds like your posts are getting truncated. It may be as simple as re-installing IE. This is a typical type of problem with M$ Software.
I can post to other websites. Only TBN seems affected. I will try reinstalling IE.
IE reinstalled. Does it work?
The mysterious world of computers. I reinstalled IE and now I can post. Thanks for your help.
/ unable to post with Explorer #14
A sad fact of MS software. Sometimes it just eats itself. This is partially the fault of the operating system; it allows applications install software that can break others. Nothing left to do but re-install. Re-instalation is high on the list of fixes.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
TRANSPORT SYSTEMS 35LX AD DOUBLE DROP (A60736)
TRANSPORT SYSTEMS...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
