Uh, Oh! 4x10 Flash Codes!!
   / Uh, Oh! 4x10 Flash Codes!! #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Just ran in to check the owners manual, Got a short long long short error. What's that? (No it's not in the owner's manual) It did say it was safe to drive. It said most reset with a "reboot", guess I'll try that!
I looked all over the machine when I bought it. There are NO "Powered by Windows XP" stickers anywhere on it...
   / Uh, Oh! 4x10 Flash Codes!! #2
Re: Uh, Oh! 4x10 Dlash Codes!!
Don't do this until you've talked to your dealer...but I reckon to "reboot" your tractor, you'll have to disconnect the battery. Probably leave it disconnected for a minute or so...
Let us know what yr dealer says to do, please.
Thanks, actually it is just a restart. and I found where Jason from K.C.Canary addressed this:
<font color="green">
Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install.
</font>
I'll retry it and if a reboot doesn't do it, then call the dealer. I didn't mention it, but the Cruise control wasn't working, either.
   / Uh, Oh! 4x10 Flash Codes!! #4
Check out THIS LINK to a previous thread on the same fault code.
Hope this helps.
EDIT: Dang, I posted the same time your second post did.
Thanks!! So far a reboot fixed it... /forums/images/graemlins/grin.gif
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
Whiteman 6' Ride On Concrete Trowel (A47384)
Whiteman 6' Ride...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
