npalen
Elite Member
when restricting a full speed centrifugal pump with a valve will the amp draw or energy used will reduce almost exactly as much as if you were reducing the pump speed with a VFDOh I am afraid using inverters, better knows as VFD's for down well pumps is not only recommended these days, but heavily pushed on every unsuspecting homeowner who is out of water and at the mercy of the installer. They use that phrase..."Adjusting the compressor motor speed gives exactly the right amount of cooling at the minimum amount of energy". Only a well pump is centrifugal, not positive displacement like a compressor, and reducing the speed actually increases the amount of energy used for the gallons of water produced. Yet millions are falling for the "energy savings lie" and think the problems inverter's or VFD's cause, as you just touched the tip of the ice burg on, are worth the added expense and short life of a "variable speed pump".
It is true that reducing the speed of a pump also reduces the energy needed to spin the pump and motor. However, using half the energy a variable speed pump has to run ten times as long to pump the same amount of water. The variable speed pump can use up to five times (500%) more energy than a standard full speed, inexpensive, and long lived well pump.
However, "home water use is (NOT) too intermittent to benefit much from a just it time water flow". The idea of the variable speed pump is good for many reasons. Working with a small pressure tank the pump will cycle for small amounts of water. Although, the benefit of "constant pressure" means the pump will never cycle during a long term use of water. A standard full speed pump with a large pressure tank will cycle less when small amounts of water are being used. But even with a large pressure tank system, cycling during long term uses of water can add up to destroy pumps much more quickly than necessary.
Along with being able to use a small pressure tank and "Things like soft start/stop, lower starting current, avoiding startup and shutdown water hammer, and reducing the torque on plumbing", there are many other benefits to a constant pressure well pump system. Out of sheer luck over thirty years ago I discovered a simple control valve can deliver "constant pressure" similar to or even better than a VFD. The difference is the valve is simple, inexpensive, and doesn't have all the problems that go with "electronic pulse width modulation", which is variable speed or VFD.
It is also an amazing fact of physics that when restricting a full speed centrifugal pump with a valve will the amp draw or energy used will reduce almost exactly as much as if you were reducing the pump speed with a VFD. I will try to find a pump horsepower curve to post. It is counter intuitive and hard to understand without a curve.
It seems like the above statement contradicts what you are saying in the second paragraph above about the inefficiency of a vfd driving a pump, but perhaps I'm reading it incorrectly.
