Oil & Fuel UDT vs. other brands
   / UDT vs. other brands #1
phastmac
Bronze Member
Hackett, Arkansas
Kubota M7060,Kubota MX 4700hst, Kubota B7100hst, Kubota RTV 900,
Does anyone know of a good fluid to use instead of kubota's UDT. Would like to save money if possible.
   / UDT vs. other brands #2
I'm as cheap or cheaper than the next man but I won't use any hydraulic fluid other than Kubota to save a dollar and sixty seven cents or whatever.:) I use SUDT in HSTs but I might if I was using UDT in a geared tractor.
   / UDT vs. other brands #3
I agree with you john, just not worth it imo.
But it was a dollar & 69 cents i think:)
   / UDT vs. other brands #4
The dealers around here don't even use UDT. Its just universal tractor fluid, get a name brand oil if that makes you feel better. Shell, Gulf, Travelers, Mystic, take your pick. The important thing is you change it occasionally.
Some get a warm and fuzzy feeling from using Kubota fluids and filters. It won't harm anything to use Shell or whatever oil and a WIX filter either.
   / UDT vs. other brands #5
If you have a GST or HST SUDT does make a difference and many HST charge pump filters do not have a real good cross.
David Kb7uns
   / UDT vs. other brands #6
I did a change using Tractor Supply hydro, which met the stated criteria of UDT. It worked fine, no foaming or other problems, but there *was* a more noticeable whine under working pressure.
I switched back to SUDT for my next change, and it's much quieter. I'm sensing a lack of power as it gets hot working though. I have enough for another change of SUDT, and may do that to more fully purge the residual TSC fluid.
I understand the valves and hose diameters are smaller on the BX series, so it may be more noticeable for my BX24 than your tractor. There are dozens and dozens of threads on this very topic, but I find it hard to get a clean search for specific issues, questions, or topics. Try a variety of single key words, and perhaps you will find some of the longer or better discussions on this.
Paul
Thanks for the replies.
2018 Toro 72in Zero Turn Commerical Mower (A50322)
2018 Toro 72in...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
2016 Genie S-45 4x4 45FT Telescopic Boom Lift (A50322)
2016 Genie S-45...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
1996 International Bucket Truck (A50323)
1996 International...
