UDT or Gear Oil
/ UDT or Gear Oil #1
Jibber
RD-13, Putnam County, New York
Kubota L3130HST 4WD, BX2350
I'm literally right in the middle of my 50 hour service on an L3130HST.
I've done everything and am now draining the front axle case. In the manual it says to use Super UDT or UDT.. OR.. 90 weight gear oil.
From the smell and consistency, I'd say that they had 90 weight in there from the factory.
My question: Hydraulic oil is so thin.. and gear oil much thicker. Can they really be interchangeable?
also..what did YOU use and why?
I realize I probably should have posted this in the generic Oil and Lubricants forum, but I'm looking for Kubota owner/operators and a quick response.
Thanks for any advice.. I've got plenty of UDT.. but gear oil would mean another trip to the dealer.
/ UDT or Gear Oil #2
for cold weather use, the Super UDT is better than the 90 weight gear lube in my opinion, which doesn't count for much. The BX series use Super UDT. If your has 90 weight, I would just put back what was in there. If you haven't drained it yet, I would just leave it alone.
/ UDT or Gear Oil
Drained.
messy job too. The drain bolts are right over the bottom lip of the wheel..
I'm using funnels trying to catch it and divert it into a drain pan... slow draining too.. further indication it's 90 weight oil.
I'm going to need to take a bath in a degreaser tub to get the oil off me after this one is done.
/ UDT or Gear Oil #4
Super UDT has a pour point of –46 C or –50.8 F max. The Amsoil gear fluid (Series 200075w-90) I used in my BX22 has a pour point of –51 F; samething for both
The Super UDTY has a Kinematic Viscosity @ 100°C of 9.00 cst and Amsoil series 2000 has a 15.7 cst. A Kinematic Viscosity @ 40°C is 45 cst for Super UDT and the gear fluid has 113.5.
For me, I like the higher KV and the fact that I wanted gear fluid for my gears.
/ UDT or Gear Oil #5
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif What did he say??????? /forums/images/graemlins/grin.gif
/ UDT or Gear Oil #6
He said:
1- Temperature: This parameter effects the process in all steps. It can be modeled by an Arrhenius expression: J = Joe(-Ea/RT). Generally, flux increases with temperature due to kinematics viscosity. Too high a temperature may result in increasing hydraulic resistance.
2- Pressure: As mentioned above, vapor difference is the driving force for pervaporation. The larger the transmembrane pressure difference is, the larger is the permeate flux. However, a large pressure difference can result in no effect or in fouling of the membrane.
3- Crossflow velocity: Within small Reynolds number range, flux can be enhanced by reducing hydraulic diameter or by increasing flow velocity. A critical velocity is necessary to achieve the maximum separation potential. However, in turbulent flow regimes, very small flow effect is observed.
4- Feed concentration: Since overall permeability of a component depends on its solubility and diffusion rate through the membrane, the permeate flux is significantly influenced by feed concentration.
I think /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif
Which I think means that at temps exceeding 100C the Amsoil will have less flux resulting in the least amount of hydraulic flow resistance.
/ UDT or Gear Oil
I think I need to go back to school to understand all that. (Physics wasn't my best subject.)
Until then.. I guess I'll just follow the manual.
That way if anything goes wrong.. they can't zap my warranty.
/ UDT or Gear Oil #8
My B2710 came with UDT in the front axle, and of course, the manual said to use UDT, Super UDT, or 80W-90 gear oil.
/ UDT or Gear Oil #9
Thanks for the explanation. I bet that you could probably write the formula for catching ghosts in space since you understand this high tech stuff. I almost caught a poltergeist once that was trying to steal my BX, but my hands slipped off of him/her when I tackled him/her since he/she was covered in Super UDT.. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ UDT or Gear Oil
I used super UDT.
I'm a ***** when it comes to manufacturers recommendations. PS.. I already had a ready supply of the stuff.
I would like to know, however, what the difference is between Kubota UDT and Super UDT.. considering the price difference. They don't tell you these things. I guess they figure that you will pay more to get the best for your tractor.. but I've never seen anything spelling out why you should go with the Super over the regular UDT.
/ UDT or Gear Oil #11
</font><font color="blue" class="small">( I've never seen anything spelling out why you should go with the Super over the regular UDT )</font>
Nor have I. The manual with my 1995 Kubota simply said UDT (Super hadn't been invented yet I guess) OR and named several (7 I think) other brands by name. Then the manual with my 1999 Kubota simply said UDT or Super UDT. I checked with the dealer I bought the tractors from, as well as another Kubota dealer, and neither of them even stocked any Super UDT at all; said they'd order it if that's what I wanted. And in fact, the other Kubota dealer said they never even use UDT; said they used another brand because it was cheaper and just as good. /forums/images/graemlins/shocked.gif I'm only guessing, but like some others on the forum, I suspect the Super UDT may be at least partially synthetic and may be better in extreme cold. Of course it may be better other times, too, but I don't know whether it is or not.
/ UDT or Gear Oil #12
My L3400 service manual says that I should use either 80/90w gear oil or UDT in the front axle. The tractor came with super UDT in the entire tractor. I talked to my dealer about the difference in UDT and Super UDT. He said that Super is for extreme temperatures and that all Kubotas come with Super but that I need only UDT since I live in the south where extreme temperatures are not a problem. I don't understand why 80/90w gear oil or UDT can be used, since they are very much different in viscosity, but I did not ask about that. Since mine has UDT in it now, I will probably use UDT when I change it.
/ UDT or Gear Oil #13
This topic came up several years ago and I still remember it well. The poster took some initiative and spoke to a Kubota service tech and asked him what to put in the front. The reply was something like, "Put yak urine in there for all I care, just don't run it dry!".
Mine has Amsoil in it and has since about 2000.
For what it's worth, the REAR axle is using the same fluid that flow thru your transmission and into your loader. You don't worry about using UDT or S-UDT and not 80w-90, do you? I don't!
John_bud
/ UDT or Gear Oil #14
Jibber, a tech rep from Amalie Oil told me that the Super Tractor Fluids can be used in everything, including the engine./forums/images/graemlins/shocked.gif I'm not putting that stuff in my motor. No way. Shell Rotella goes there. /forums/images/graemlins/cool.gif
/ UDT or Gear Oil #15
I must confess. I put two quarts of SUDT in my engine before realizing the error of my ways. This is only one of the times my head was where the sun don't shine. The other times are a secret for now. The motor oil I have comes in a gallon jug just like the SUDT and I was transfering the oil from the gallon into a quart container to have better access to the filler port on the engine. The gallon jugs are too large to get in there. I had two quarts in the engine before realizing what I was doing. I never ran the engine on SUDT, I drained and flushed with other motor oil before filling with the required engine oil. It hasn't seized so I guess I'm ok. It's not something recommended in the manual so don't take anyones word for it. I don't believe the SUDT has the appropriate properties for use in internal combustion engines. Use motor oil in engines. SUDT is a good gear lube, don't hesitate to use it in the front diff if it's all you have handy, it's just much higher priced than 80/90.
Best of luck,
Martin
/ UDT or Gear Oil #16
Super UDT, per the spec, is able to be installed in some interval combustion engines. It is like people think UDT and Super UDT only differ by pour points etc.
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
Pallet Fork Extensions (A64047)
Pallet Fork...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
20’x30’ All-Steel Carport w/ Enclosed Sidewalls (A64047)
20’x30’...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
