U5030 vs XU 5055 HELP!
   / U5030 vs XU 5055 HELP! #21
I'm going to step out and show my ignorance about this, but what us the issue with "covering your tire tracks" with the cutter. I see it talked about often but not for sure why. I understand wanting to save time by using the widest cut that your tractor (and pocketbook) can handle but was wandering about this.
I'm definitely getting a 6 footer because of cost and use at the deer lease. Also getting the U5030 with ag tires, and steel canopy.
   / U5030 vs XU 5055 HELP! #23
You want a cutter that is at least as wide as your tractor because a narrower cutter won't mow close to fence lines, trees, etc.
   / U5030 vs XU 5055 HELP! #24
Go with the Tier 3 Engine till they run our of T3's. Personally, my dealership bought a ton of tractors to keep the T3s in stock as long as we could.
I'm finally getting around to posting pics of my tractor. It's been a very busy holiday schedule. Sorry it took me so long. I ended up buying a U5030.
   / U5030 vs XU 5055 HELP! #27
I didn't get the canopy for mine. What did that run you, if you don't mind me asking ? I've hot a fiberglass bolt on Westendorf canopy that I am thinking about taking off my Kubota , cleaning up and painting the closest color to LS blue as I can find. If the price isn't too bad though , I may just buy one.
Thanks. Now trying to figure out which rotary cutter model to go with. I think I've narrowed it down between a Bush Hog BH 26 or a Land Pride RCR 2672 or RCF 2772?
$24K for tractor/fel and $450 for the canopy
   / U5030 vs XU 5055 HELP! #30
Nice looking tractor. If only it was available in HST .... if only
:D
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Portable Restroom (A54865)
Portable Restroom...
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
