u5030 adult supervision
   / u5030 adult supervision #1
24 frames
hockley Texas
LS5030 JD 2440
I have a u5030 no emission 5 years old with 500 hours on it, it died. I checked fuel filter and bled off air Went to injector pump and bled off air. loosened injector lines But not getting fuel to injectors. All fuses look good I noticed my dash info does not seem to work, my glow plug indicator does not light up. I am 60 and THANK YOU for any and all adult supervision
   / u5030 adult supervision #2
I'd check ALL ground connections on the tractor. first thing I check anytime there's any electrical problems are the fuses, then the grounds
Thanks I am thinking too much forgot that one
Papachaz you win I traced wiring harness in engine bay found a wire melted to metal hydraulic line. Removed harness took in house to solder it up will replace tomorrow. will update Thanks for getting my thinking cap to working
   / u5030 adult supervision #5
:thumbsup:
hope that was it!
you have to love finding that a problem is really something simple
Yep Papachaz made repairs inside wrapped harness in muffler heat shield wrapped hot pipe in heat shield Put it back on cranked right up the cows were happy they got some round bales. Papachaz I prefer the fixes you have to look for and are very cheap opposed to the fixes that are easy to find and expensive haha Thanks again stay warm
   / u5030 adult supervision #7
good deal! glad it was something simple! I know the cows are happy for sure
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
