u5030 adult supervision
   / u5030 adult supervision #1
24 frames
hockley Texas
LS5030 JD 2440
I have a u5030 no emission 5 years old with 500 hours on it, it died. I checked fuel filter and bled off air Went to injector pump and bled off air. loosened injector lines But not getting fuel to injectors. All fuses look good I noticed my dash info does not seem to work, my glow plug indicator does not light up. I am 60 and THANK YOU for any and all adult supervision
   / u5030 adult supervision #2
I'd check ALL ground connections on the tractor. first thing I check anytime there's any electrical problems are the fuses, then the grounds
Thanks I am thinking too much forgot that one
Papachaz you win I traced wiring harness in engine bay found a wire melted to metal hydraulic line. Removed harness took in house to solder it up will replace tomorrow. will update Thanks for getting my thinking cap to working
   / u5030 adult supervision #5
:thumbsup:
hope that was it!
you have to love finding that a problem is really something simple
Yep Papachaz made repairs inside wrapped harness in muffler heat shield wrapped hot pipe in heat shield Put it back on cranked right up the cows were happy they got some round bales. Papachaz I prefer the fixes you have to look for and are very cheap opposed to the fixes that are easy to find and expensive haha Thanks again stay warm
   / u5030 adult supervision #7
good deal! glad it was something simple! I know the cows are happy for sure
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
