Posthole Digger U-joints for Ford Posthole digger
   / U-joints for Ford Posthole digger #1
scazmando
'89 Cat D-4C, '40 9n, '58 601, '60's M/F 3165
Looking for u-joints for a Ford 22-08 post hole digger.
Can anyone help?
   / U-joints for Ford Posthole digger #2
I looked at the CNH and can't find a model 22-08 anything.
Are you sure you have the numbers right?
Does the phd happen to look like the one in the picture?
If so it is a Ford 903 and the dealer does still support most parts on them.
Otherwise you could just take your old yokes to your nearest clutch and U joint shop and they can probably match them up.
   / U-joints for Ford Posthole digger #3
I am sure your local auto parts store carries them, but the model number is probably not something they can look it up by.
Measure it. Diameter of all 4 caps, and length from cap to cap. Sometimes there are two different size caps and lengths to adapt to different size yokes.
Or just take one out and take to a parts store.
Got the numbers wrong. I believe its a 22-63. Looks identical to the one in the pic.
Thanks for your help.
   / U-joints for Ford Posthole digger #5
Any driveshaft shop will have U-joints to fit any PTO shaft AFAIK...
   / U-joints for Ford Posthole digger #6
I am interested in purchasing this 22-63 PHD from you. It is needed for testing. We can replace it with a newer one in proper condition. Please contact me at rksinc@mac.com
   / U-joints for Ford Posthole digger #7
Can you send me close up pictures of the drive shaft guard at the gearbox with a tape measure in the photos? Also the Ford label showing model and serial number? Also some other photos from all angles. I notice that the lever for adjusting the angle of the auger is missing, but I may be interested in purchasing this auger assembly because it is needed for testing. We would of course replace it with a newer model in better shape, equipped with the PTO shield (not on this unit). Let me know. Thanks. rksinc@mac.com
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
