Posthole Digger U-joints for Ford Posthole digger
   / U-joints for Ford Posthole digger #1
scazmando
'89 Cat D-4C, '40 9n, '58 601, '60's M/F 3165
Looking for u-joints for a Ford 22-08 post hole digger.
Can anyone help?
   / U-joints for Ford Posthole digger #2
I looked at the CNH and can't find a model 22-08 anything.
Are you sure you have the numbers right?
Does the phd happen to look like the one in the picture?
If so it is a Ford 903 and the dealer does still support most parts on them.
Otherwise you could just take your old yokes to your nearest clutch and U joint shop and they can probably match them up.
   / U-joints for Ford Posthole digger #3
I am sure your local auto parts store carries them, but the model number is probably not something they can look it up by.
Measure it. Diameter of all 4 caps, and length from cap to cap. Sometimes there are two different size caps and lengths to adapt to different size yokes.
Or just take one out and take to a parts store.
Got the numbers wrong. I believe its a 22-63. Looks identical to the one in the pic.
Thanks for your help.
   / U-joints for Ford Posthole digger #5
Any driveshaft shop will have U-joints to fit any PTO shaft AFAIK...
   / U-joints for Ford Posthole digger #6
I am interested in purchasing this 22-63 PHD from you. It is needed for testing. We can replace it with a newer one in proper condition. Please contact me at rksinc@mac.com
   / U-joints for Ford Posthole digger #7
Can you send me close up pictures of the drive shaft guard at the gearbox with a tape measure in the photos? Also the Ford label showing model and serial number? Also some other photos from all angles. I notice that the lever for adjusting the angle of the auger is missing, but I may be interested in purchasing this auger assembly because it is needed for testing. We would of course replace it with a newer model in better shape, equipped with the PTO shield (not on this unit). Let me know. Thanks. rksinc@mac.com
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
2013 Acura ILX Hybrid Sedan (A50324)
2013 Acura ILX...
