u joint availability
   / u joint availability #1
99yanmar
Wausau Wisconsin
1999 Yanmar F250 1981 Case 580D tractor backhoe
I have a yanmar tiller that has a quick attach bracket which couples my pto to the tiller,the problem is my u joints are worn out.I believe ther metric and can find them locally[central wisconsin]Where can I get Yanmar Parts?
   / u joint availability #2
Others may on here may have them . Or, you can call fredricks at (256) 773-9951. I know he imports these tillers and may have the parts you need....Or, Danny parker (205) 646-3033 may be able to get you the parts
   / u joint availability #5
We have about 25 of the shafts on a pallet, mostly the male ends.
Why is it everyone breaks the female end of those things ??
Ernie
   / u joint availability #6
I had to replace the u-joints in my shaft and had the same problem. Ultimatly, I was able to get a set close (but not right) from Baum Hydraulics. Before calling them, take your old joints apart and mic them. They will need these dimensions. I found a set that was close, but the width was just a bit too much. I couldn't get the C clip back in. I ended up grinding a small amount of material off the cross below each cup and that did the trick. I don't use the tiller very much, but it's been togther and through several gardens now with no problems.
Remember guys: These tiller are really cheap, but they're worthless with out that driveshaft! If you are getting a tiller, make sure it comes with the correct shaft and the joints are tight!
   / u joint availability #7
If you don't want to get an a assembly from Ernie then,
Just take the assembly to a drive shaft shop and they will match up and repair.
These usually break from tilling too deep, this creates a sharp angle on the u-joint and something has to give ( don't ask how I know this).
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
RYOBI 18V ELECTRIC 13" PUSH LAWN MOWER (A51248)
RYOBI 18V ELECTRIC...
