U bolts for ROPS
   / U bolts for ROPS #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I want to strap my lights on the rops with 3" x 3" U Bolts. auto parts can only get them in 1/2" stud, I was thinking 1/4" or 5/16" would be heafty enough for a light. Any thoughts
   / U bolts for ROPS #2
John Deere parts has "black" U-bolts to match the ROPS... about ~ $2.... maybe 5/16" ?
   / U bolts for ROPS #3
Check your local Ace Hardware. I found the ones I needed there.
Hoss
   / U bolts for ROPS #4
DDT, I've used large stainless steel worm gear clamps that are available in plumbing supplys. As you tighten them down with a littte tapping they conform to any shape and give a clean installation.
   / U bolts for ROPS
Thanks for the help. I called my JD dealer and he did not know of any that size. Sounds like I can find some eles where.
   / U bolts for ROPS #6
DDT, If you just want 1/4" u-bolts, they are easy to custom make. I have done it several times. Just take 1/4" threaded rod and bend it in a vise to the size you need. Then cut some 3/4" or 1" wide flat stock to the right length and drill a couple of holes to make the clamp. You can make them any size or shape you need. For installations where I do not want them to scratch or to absorb vibration, I cover the threaded rod with black rubber fuel line hose. That makes it look better too.
Andy
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
