i have a dead tz.
all started fine as usual when i moved the tz out of shed .
would have been running for around 5 minutes . i shut it down and when i returned in the afternoon it would not start as the glow plug light failed .
starter was still operating at this stage .
next day i returned to see if it had miraculously reset itself and turned the key to start and this time there was no starter as well .
i have replaced fuses and have put test light on them and they seem fine .
all lights and fuel pump are still operating with ignition on.
i disconnected the wire to the fuel shut off soleniod and no voltage here .
i did run direct from batt positive to fuel shut off soleniod and it clicks in & out with current .
have bridged seat switch with no result .
the tz did not fail when it was operating , it just developed this problem after i shut it down and returned to use in afternoon.
i have now stripped it down to the chassis chasing this gremlin.
have not yet looked at ignition switch.
tz has 350hrs clocked up and is 2005 model.
park brake alarm does not work and i have not suspected this as the problem as it has worked intermittently for 2 -3 years now.
i also have power at the glow plug buss bar
any suggestions out there from experience where i should target problem
thanks
thanks
