TZ18DA HST info needed
   / TZ18DA HST info needed #1
holzboat
Long Island, NY
JD 4110, JD X595, JD 4100
Hi,
I'm looking at a TZ18DA that is not running. The head is off so there is no chance of running it. The owner says that he can only move it by picking it up with a forklift, the wheels won't spin if he tries to tow it. Is there any bypass valve or procedure which will allow the wheels to freewheel? He can put it in my truck with the forks but I'd still have to roll it down ramps to get it out of the truck.
Thanks,
Roger
   / TZ18DA HST info needed #2
Hi, I'm looking at a TZ18DA that is not running. The head is off so there is no chance of running it. The owner says that he can only move it by picking it up with a forklift, the wheels won't spin if he tries to tow it. Is there any bypass valve or procedure which will allow the wheels to freewheel? He can put it in my truck with the forks but I'd still have to roll it down ramps to get it out of the truck. Thanks, Roger
I have the TZ24DA and manual says "Place transmission range lever in neutral, and disengage the PTO clutch lever to tow tractor"
Thanks. I'm hoping to find time to look at it again tomorrow. It was doing a pretty good impersonation of a snow bank when I saw it a few days ago. Hopefully I can dig it out enough to see the whole tractor this time.
KBH 25T Tender (A56438)
KBH 25T Tender...
2226 (A58376)
2226 (A58376)
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
