TZ18DA HST info needed
   / TZ18DA HST info needed #1
holzboat
Long Island, NY
JD 4110, JD X595, JD 4100
Hi,
I'm looking at a TZ18DA that is not running. The head is off so there is no chance of running it. The owner says that he can only move it by picking it up with a forklift, the wheels won't spin if he tries to tow it. Is there any bypass valve or procedure which will allow the wheels to freewheel? He can put it in my truck with the forks but I'd still have to roll it down ramps to get it out of the truck.
Thanks,
Roger
   / TZ18DA HST info needed #2
Hi, I'm looking at a TZ18DA that is not running. The head is off so there is no chance of running it. The owner says that he can only move it by picking it up with a forklift, the wheels won't spin if he tries to tow it. Is there any bypass valve or procedure which will allow the wheels to freewheel? He can put it in my truck with the forks but I'd still have to roll it down ramps to get it out of the truck. Thanks, Roger
I have the TZ24DA and manual says "Place transmission range lever in neutral, and disengage the PTO clutch lever to tow tractor"
Thanks. I'm hoping to find time to look at it again tomorrow. It was doing a pretty good impersonation of a snow bank when I saw it a few days ago. Hopefully I can dig it out enough to see the whole tractor this time.
2860 (A56857)
2860 (A56857)
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2015 Komatsu WA380-8 Articulating Wheel Loader, S/N A74124, PIN# KMTWA130CFNA74124, Diesel Engine, (A59076)
2015 Komatsu...
Mini Excavator Hydraulic Thumb (A55272)
Mini Excavator...
