TZ18DA Blown 5A Fuse
/ TZ18DA Blown 5A Fuse #1
Vette Girl
I have a TZ18DA that won't start because of a blown 5A fuse. Whenever I try to install a new fuse, it blows immediately (I even tried a 10A fuse and that blew). The fuse diagram said the 5A is for the safety control unit, brake switch. Any suggestions on where the short is or how to fix the issue?
/ TZ18DA Blown 5A Fuse #2
As you can read the diagram, try disconnecting any connector plugs - one by one - in that circuit. Or to save fuse money, disconnect every plug, then start putting them back together. When the fuse blows, that's going to get you closer. Maybe that will help you isolate the short.
Putting in a larger fuse will eventually show you the problem spot, but you will have cooked insulation - or worse - to fix.
Good luck, Dave.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2019 JCB 457 (A60462)
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
