Typical FEL Mount Bolt Torque?
/ Typical FEL Mount Bolt Torque? #1
mmranch
Crested Butte, CO
TYM T603
The manual for my FEL is basically a system description and parts list. There is no info about installing the FEL or bolt torque, etc.
I've got FEL mount bolts in the sizes of of 19mm, 22mm, 24mm gold color stamped with 10.0. These are for mounting the FEL mounts to the tractor.
What would be a reasonable torque for the 24mm bolt for example?
Thanks!
/ Typical FEL Mount Bolt Torque? #2
19 mm, 22 mm and 24 mm is the head size, right? That means it's a M12, M14 and M16 bolt respectively and the grade is 10.9.
There should be a chart for bolt torques on the manual. Anyways, here is a table for torques of metric bolts.
https://i.pinimg.com/originals/63/3e/bd/633ebd769611f5d828e58fdac6d0e945.jpg
/ Typical FEL Mount Bolt Torque? #4
Good-n-tight ... The real danger is a loose bolt. Just get a wrench and go over every bolt you can find. If you find one that turns with a firm tug... investigate the whole piece further.
torque charts for metric bolts class 10 posted previously
Thanks very much for all the info!
Thanks again.
RoadTec RP190 (A63689)
211299 (A62131)
211299 (A62131)
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63689)
Magnolia Trailer...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
