Type "A" ATF
   / Type "A" ATF #1
KENSFM
MA
JD 2210 JD318 JD332
Type \"A\" ATF
Does anyone know if type "A" automatic transmission fluid is still available. I have an older JD 112 that calls for this type fluid in the hydraulic system. Wonder if Dextron would be OK?
Thanks, Ken /forums/images/graemlins/smile.gif
   / Type "A" ATF #2
Re: Type \"A\" ATF
Checked a bottle of Dexron III/Mercon I have in the garage. It states that Dexron III/Mercon replaces Type A, Dexron, Dextron II, IIE, III and Mercon fluids. Believe you are OK in using it for your JD 110.
   / Type "A" ATF #3
Re: Type \"A\" ATF
Type A is still available. I get it at NAPA for a couple of power steering units and an old Ford Pickup I have. Other places have it as well. My friends in the transmission rebuilding business say not to use dexron in a type A application.
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
43029 (A51691)
43029 (A51691)
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
