Comparison TYM vs LS
/ TYM vs LS #11
I'm not familiar with the LS, but have a TYM-233 for 2.5 years and have 110 hours on it. I've found it very dependable and does everything asked of it. Mine has a 5 year warranty; this winter I took it back to the dealer for some minor issues which he took care of. Nothing bad to say about TYM....FWIW!
/ TYM vs LS #12
Hello,
I am new to the tractor market. I am in north idaho and there is one LS dealer 2hours away. I like him and he states that if he cannot fix the problem over the phone he will come to me, within a week.... There are 3 TYM dealers in the area, one of whom is the dealer with the LS dealership. The same LS/TYM seems to be pushing TYM. So initially I liked the brawn of the LS (heavier and more pto power) but I think I should seriously look at TYM. Any thoughts about this would be helpful.
Thank you
I looked pretty hard at the T233 and liked it for it's ergonomics and it has a pretty bulletproof Mitsubishi engine, the sad part is that in New Hampshire the one dealer that sold them is dumping TYM and there are no dealers in Maine or Mass only one in VT and he has 1-3 year old "New" tractors on his lot, some are pink from sun fading and the tires are all weather cracked. LS is a new name but LG who owns them sold tractors for years under the Long/Agribusiness brand. Since then they have made a deal with New Holland and they make all the smaller New Hollands, so you have another entire network of dealers and parts if you buy the LS
/ TYM vs LS #13
I thought there is still one dealer in Massachusetts
/ TYM vs LS #14
Well it looks like Cabelas is going to be selling rebranded TYM's soon.
/ TYM vs LS #15
Something to consider is that you can get parts, and even warranty service for most LS models at NH or Case dealers....at least the models that are the same as the Boomer/Farmall B models. The only exception should be loader parts since NH and Case use a different, weaker, loader.
/ TYM vs LS #16
I don't own either brand, but I did spend time recently scouring over some LS tractors. They are well built, with one exception- the telescoping stabilizers are poorly and weakly designed. If I were shopping, that wouldn't be a deal breaker (I'd just build a heavy duty set, like the photo), but it is an observed weak point, in my opinion.
The 5/16" tab on either end will bend and deform under repeated load- the set that I built compensated for that.
/ TYM vs LS #17
We have had our TYM T293 HST for 2 1/2 months now, have about 85 hours on it and have had only one small problem. The ball joint boots that came on it initially were pretty thin and they have torn. The dealer offered to replace them but I requested he just send me the replacements. They are much improved from the originals.
I could not be happier with TYM
Ditto on the boots and heavier replacements.
We have had our 293 for about 15 months and 150 hours. Other than the aforementioned thin boots, we have had no problems whatsoever. I did not consider LS as there are no dealers anywhere near me, so I cannot speak to them at all.
Good luck!
/ TYM vs LS #18
http://s65.photobucket.com/user/br549_red/media/001_zps3c9d41e6.jpg.html
There has been a minor occurrence of problems related to the stabilizer arms ... but its not with the arm construction, it has been with the bracket itself that mounts to the tractor frame. The angle at which the stabilizer arm mounts to the bracket causes stress on the bracket, and if the arm binds on the bracket at the right angle with the right force, it can break the bracket. It's an easy fix, as the bracket just bolts onto the frame. So, I wouldn't worry about the stabilizer arms and themselves, they are not the weak link in that setup.
I'm very happy with my LS, I think it's a well built tractor. There seem to be very few complaints about quality issues regarding LS tractors, and mine has been no exception. While there are minor things I would change about it from an ergonomic standpoint (though I would with ANY tractor), operationally it has been perfect.
If I was shopping again, I would have to consider the TYM T503/603 (same as the Mahindra 5010/6010 I think) ... as I believe the 603 is available in HST, and has a nice loader.
But like was already mentioned, LS has much better dealer support, especially considering you can get parts and service from LS, New Holland, or Case dealerships.
/ TYM vs LS #19
Wow, very nice looking stabilizer you built! I think the LS design might be a bit better than it gets credit for...they will break before the expensive parts start breaking....a good thing. I accidentally bounced the side of my RFM off a stump, and it put one heck of a side loade on the stabilizer, so it bent. I cut out the bend, welded it back together, and it's been fine ever since.
Still, I'd love to get something more significant to help control my counterweight (over 1,300lbs)....are you considering making more of you design? I think folks would buy them if you made them available.
/ TYM vs LS #20
Really depends on what models you are looking at and what you want to do. Both I think are pretty good the biggest difference we saw when looking at both makes in the 70-100 HP range is the TYM has a power shuttle in the T723 74HP the LS 7010 72HP does not but is about 800lbs lighter. The TYM 1003 (Mahindra 100HP) is a whole 1000lbs heavier than the LS 7040 (100HP model). We liked the perkins power in the TYM's thats why we went with them.
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
Takeuchi TB290 (A60462)
Takeuchi TB290...
2014 FREIGHTLINER CASCADIA 125 6X2 MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
2010 Volkswagen Routan Van (A59231)
2010 Volkswagen...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
