Comparison TYM vs LS
/ TYM vs LS #1
tjt35
kubota 4310
Hello,
I am new to the tractor market. I am in north idaho and there is one LS dealer 2hours away. I like him and he states that if he cannot fix the problem over the phone he will come to me, within a week.... There are 3 TYM dealers in the area, one of whom is the dealer with the LS dealership. The same LS/TYM seems to be pushing TYM. So initially I liked the brawn of the LS (heavier and more pto power) but I think I should seriously look at TYM. Any thoughts about this would be helpful.
Thank you
/ TYM vs LS #2
tj - What are you going to use the tractor for? What size are you looking at? I have had A TYM for two years now 90+ hrs and have no trouble with it. The local dealer in Post Falls has been responsive to my questions and has always been friendly when I stop by.
/ TYM vs LS
Joeyd,
Thanks for your reply. Both TYM and LS has appropriate size models for me. Thats the easy part. I have become very comfortable with the LS line and when I read the forums there seems to be much less complaining from the LS crowd but clearly I would be covered better by TYM dealerships, so I am continuing to ask questions and get feedback
/ TYM vs LS #4
I do not know the first thing about LS tractors so I can not speak about them. I do like my TYM so far it has been reliable and it has suited me for what I do just fine. You have the unique situation where you have a dealer selling both brands. I would have the dealer compare the models you are interested in feature for feature, dollar for dollar. Get on them and drive them around and see how they fit and operate and just go with what you feel would be the best tractor for what you need and like the best.
Al
/ TYM vs LS
Thank you all very much for your input. I need to do more research and then get back to TBN
/ TYM vs LS #6
We have TYM 330 HST 550 hours. It had small leak around the sight glass on the transmission right when it was new. Dealer gave me new part and it took about 5 minutes to fix. Since then the tractor was flawless.
/ TYM vs LS #7
We have had our TYM T293 HST for 2 1/2 months now, have about 85 hours on it and have had only one small problem. The ball joint boots that came on it initially were pretty thin and they have torn. The dealer offered to replace them but I requested he just send me the replacements. They are much improved from the originals.
I could not be happier with TYM
/ TYM vs LS #8
From everything that I've read, heard, and seen...you're probably not going to go wrong with either one. Pretty helpful, I know. lol
/ TYM vs LS #9
I cant speak to TYM as there arent any dealers near me. I have seen a lot of them in other countries ie Peru, Nigeria, Mexico where the bigger Ag tractors are popular.
Dealers come and go at will it seems. One long time NH dealer shut down and now sells ATV's, who would have thought that would happen. Every ones says get a good dealer. My take is that friendly dealers while being good to negotiate with and whatever doesnt guarantee they will be selling your brand next year so get a good tractor to begin with.
I like my LS even without having a nearby dealer as mine is a short 60 miles away and what with the 3 broken parts in over 2 years. Only parts I have needed were filters which were drop shipped to me with exception fuel tank which I had to go get and seat suspension and drawbar bracket which I took the tractor in for repair and full checkout as 2 year bumper to bumper warranty was expiring. Everything was ok and new parts fitted . So everything that I broke has been fixed free of charge (seat suspension, drawbar attachment bracket, fuel tank). It only took about 3 days to get the seat and DB bracket last month although we did fix the seat bracket by welding up the pin that broke. It took 6 weeks to get the new fuel tank in as it had to come from Korea. This happened in spring of 2011 right after they started selling them and about 6 months after I bought it. Even though the fuel tank breaking was partially my fault for running over trees and saplings, LS redesigned the bracket holding the tank and skid plate, sent me a new tank complete with cap and fuel sending unit intact. I still have the new one in my shop waiting on my JBWELD repair on the cracks to fail which most contributors on TBN thought would happen in less than 6 months. Its been about 18 months and counting for the home repair with epoxy.
I can say that LS is very pro-active in redesigning a failed part when it appears to be a problem. The fuel tank attachment was redesigned to protect the tank from fractures, the seat suspension was redesigned to be stronger even though the problem was a faulty inadequate weld and the drawbar was also redesigned to be a bit stronger. They dont seem to just set on a problem like I have seen complaints on TBN from other brands.
The power on the P7010 is phenomenol. Yesterday I was picking up some brush using the FEL and once when repositioning the FEL so it was closer to brush while running at 1000 rpm. I heard a little ping from the disc blade but thought it had just hung a vine or something and next thing I know a 10" diameter x 50 foot pine tree comes crashing down beside my tractor. I had hit it with the outside blade on my 8 foot disc as I turned and just pulled it right over without a groan from the tractor. I was very lucky on that one that it fell parallel to the tractor and not on top of it and also missed my brother in law who was loading brush on the other side of the tractor.
I am pretty rough on equipment but the LS has stood the test for ruggedness and reliability. The engine oil at 50 hour change was clear as new oil which was surprising for a diesel. Everything is fairly easy to service although I did have to go buy a 25mm hex key wrench to change the engine oil (the drain plug required that size to remove the two plugs.
/ TYM vs LS #10
Would you mind saying which models of each brand you are considering? Knowing what you are looking at will get some other types of responses I would think. ;)
/ TYM vs LS #11
I'm not familiar with the LS, but have a TYM-233 for 2.5 years and have 110 hours on it. I've found it very dependable and does everything asked of it. Mine has a 5 year warranty; this winter I took it back to the dealer for some minor issues which he took care of. Nothing bad to say about TYM....FWIW!
/ TYM vs LS #12
Hello,
Thank you
I looked pretty hard at the T233 and liked it for it's ergonomics and it has a pretty bulletproof Mitsubishi engine, the sad part is that in New Hampshire the one dealer that sold them is dumping TYM and there are no dealers in Maine or Mass only one in VT and he has 1-3 year old "New" tractors on his lot, some are pink from sun fading and the tires are all weather cracked. LS is a new name but LG who owns them sold tractors for years under the Long/Agribusiness brand. Since then they have made a deal with New Holland and they make all the smaller New Hollands, so you have another entire network of dealers and parts if you buy the LS
/ TYM vs LS #13
I thought there is still one dealer in Massachusetts
/ TYM vs LS #14
Well it looks like Cabelas is going to be selling rebranded TYM's soon.
/ TYM vs LS #15
Something to consider is that you can get parts, and even warranty service for most LS models at NH or Case dealers....at least the models that are the same as the Boomer/Farmall B models. The only exception should be loader parts since NH and Case use a different, weaker, loader.
/ TYM vs LS #16
I don't own either brand, but I did spend time recently scouring over some LS tractors. They are well built, with one exception- the telescoping stabilizers are poorly and weakly designed. If I were shopping, that wouldn't be a deal breaker (I'd just build a heavy duty set, like the photo), but it is an observed weak point, in my opinion.
The 5/16" tab on either end will bend and deform under repeated load- the set that I built compensated for that.
/ TYM vs LS #17
Ditto on the boots and heavier replacements.
We have had our 293 for about 15 months and 150 hours. Other than the aforementioned thin boots, we have had no problems whatsoever. I did not consider LS as there are no dealers anywhere near me, so I cannot speak to them at all.
Good luck!
/ TYM vs LS #18
http://s65.photobucket.com/user/br549_red/media/001_zps3c9d41e6.jpg.html
There has been a minor occurrence of problems related to the stabilizer arms ... but its not with the arm construction, it has been with the bracket itself that mounts to the tractor frame. The angle at which the stabilizer arm mounts to the bracket causes stress on the bracket, and if the arm binds on the bracket at the right angle with the right force, it can break the bracket. It's an easy fix, as the bracket just bolts onto the frame. So, I wouldn't worry about the stabilizer arms and themselves, they are not the weak link in that setup.
I'm very happy with my LS, I think it's a well built tractor. There seem to be very few complaints about quality issues regarding LS tractors, and mine has been no exception. While there are minor things I would change about it from an ergonomic standpoint (though I would with ANY tractor), operationally it has been perfect.
If I was shopping again, I would have to consider the TYM T503/603 (same as the Mahindra 5010/6010 I think) ... as I believe the 603 is available in HST, and has a nice loader.
But like was already mentioned, LS has much better dealer support, especially considering you can get parts and service from LS, New Holland, or Case dealerships.
/ TYM vs LS #19
Wow, very nice looking stabilizer you built! I think the LS design might be a bit better than it gets credit for...they will break before the expensive parts start breaking....a good thing. I accidentally bounced the side of my RFM off a stump, and it put one heck of a side loade on the stabilizer, so it bent. I cut out the bend, welded it back together, and it's been fine ever since.
Still, I'd love to get something more significant to help control my counterweight (over 1,300lbs)....are you considering making more of you design? I think folks would buy them if you made them available.
/ TYM vs LS #20
Really depends on what models you are looking at and what you want to do. Both I think are pretty good the biggest difference we saw when looking at both makes in the 70-100 HP range is the TYM has a power shuttle in the T723 74HP the LS 7010 72HP does not but is about 800lbs lighter. The TYM 1003 (Mahindra 100HP) is a whole 1000lbs heavier than the LS 7040 (100HP model). We liked the perkins power in the TYM's thats why we went with them.
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2154262019 FAE UMLV SSL- 150VT HYD MULCHING HEAD (A65053)
2154262019 FAE...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2016 Toyota Tundra Ext. Cab Pickup Truck (A64556)
2016 Toyota Tundra...
