TYM - T474HC RPM loss problem fixed.
   / TYM - T474HC RPM loss problem fixed.
It's only been a week since the first post. If it is fixed, that's pretty awesome. Can't wait to hear what the issue was.
The tractor has been down for over two weeks, almost three. But I feel fortunate they have it fixed.
It was an unfortunate time, because we finally finished with a side job from over the summer, and I was ready to get to work on the property with the tractor. But that is when break downs happen. Right when you are needing them.
Now I’m away on a vacation to help my daughter’s family move from their current house to their new one. And to hold, hug, and wrestle with the grandchildren. So I won’t be able to use the tractor until next week. LOL
Just found out a couple minutes ago. Pinched fuel line.
:picard:
The loader was pinching it just a bit. They took the loader off and moved the line so it can’t happen again. I won’t see it until I get home next week. Must of been a problem from the factory. Can you say quality control?
   / TYM - T474HC RPM loss problem fixed. #25
:picard:
Great news Gas . . . was the loader made and installed at the tractors parent company?
   / TYM - T474HC RPM loss problem fixed. #26
I'm trying to figure out how the loader pinches the fuel line. Unless my 4820 is a lot different
   / TYM - T474HC RPM loss problem fixed. #30
Not sure how the T474 fuel system is laid out but is it possible this has blow molded fuel tank wrapped around close to loader frame mount and a hose got pinched. Agree don’t understand how would be by front axle unless loader has frame rails on both sides of the engine.
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
