TYM - T474HC RPM loss problem fixed.
/ TYM - T474HC RPM loss problem fixed. #1
Gasifier
St. Lawrence River Valley, N.Y.
Currently tractor less ;( 😂
Problems with my TYM. Here we go again.
:confused:
T474HC
I bought this tractor about the end of May. I have used it very little because of job and family obligations over the last four months. It has less than 50 hours on it and it’s in the shop.
Keeps losing RPMs to the point of almost stalling. Took it to the closest TYM dealer and asked them to do the 50 hour service and find out what is going on with it.(47 hours) They completed the 50 hour service and I think it was $390ish dollars. No problem. Thanks for doing it.
They thought they knew what the problem was and showed me how the hydraulic filter’s insides had collapsed. What? Said they never seen it before. Must of been a defect from factory. Me either. Never seen that before. But everything worked fine now when they drove it. Brought it home and found time to use it the next day or two. Did a little moving of sticks and stones in the bucket and after 10-12 minutes I started to do some back dragging to level the area off. RPMs dropped to almost nothing again and kept doing it. I had to drive it back slowly to the barn. Called them up and they said okay we will come and pick it up.
It’s been two weeks today. They are a busy place. I get it. They told me last Saturday that they thought they would get it in Monday and have it back to me Monday or Tuesday afternoon. It’s now Saturday morning. Frustrating. To say the least. Just dam depressing, souring my mood toward everything. I have literally mowed grass with it, moved a couple buckets of dirt, rocks, sticks, and turned the horse manure pile several times. About 47 hours on it.
No response when I call them. Get answering machine and it says to leave a text. Did that. No response. Just lost on what to do. Wait. I guess.
Now I have the time to put it to work and I can’t even use my new tractor.
I guess I should have spent the extra $20,000 and bought a new Kubota? Or better yet. Bought a used Kubota about the same price? Never had any problems with the Kubotas.
C’mon TYM. Help get my tractor fixed!
Owner called me. Turns out he has a technology problem with his communication system. [that texting system to e-mails/messaging] Technology. :rolleyes: He had everything cleaned up and then all of a sudden it dumped 75 text messages to him from different people. He called me right up and said they’re figuring it out. He’ll call me Monday or Tuesday whenever they get it done. He has put a very experienced diesel mechanic on troubleshooting it. Fingers crossed.
/ TYM - T474HC RPM loss problem fixed. #3
How would hydraulic filter collapsing cause engine RPM’s to drop to point it wouldn’t run? Diesel fuel filter or air filter yes but don’t understand hydraulic filter doing this unless somehow loading engine to point of stalling.
Glad dealer responded and hopefully will get the resolved.
Good question. And nothing makes you feel good about having problems this early with a new tractor. Nothing.
/ TYM - T474HC RPM loss problem fixed. #5
So true, if like me it really makes you wonder on what did I do…
They had also told me they should have it to me last Monday or Tuesday afternoon. That didn’t happen. What did?
/ TYM - T474HC RPM loss problem fixed. #7
That's what I did ... 😁
I agree the collapsed HYDRAULIC filter should have NOTHING to do with the ENGINE RPM's dropping!
Bogus excuse! If it was defective filter(s) from the factory, it certainly would not have taken 47 HOURS to notice it!!!
To your credit you had them do the service, so there is now a record of that being done, no more BOGUS EXCUSES anymore ... Fix it right, give you a different tractor, or all your money back!
/ TYM - T474HC RPM loss problem fixed. #8
Does your tractor have a fuel throttle on your steering wheel? The reason I ask is because one of my tractors when new had a similar problem (loosing RPM's) and turned out to be the throttle located on the steering wheel was loose from the factory. 🤷‍♂️
Throttle ON the steering wheel?
There is a hand throttle lever on the dash to the right of the steering wheel.
/ TYM - T474HC RPM loss problem fixed. #10
That's probably it (hand throttle), you might have that looked at . . . that turned out to be my problem.
/ TYM - T474HC RPM loss problem fixed. #14
Lots of new tractors have Yanmar engines and other parts/stuff from them. So your hand throttle was malfunctioning? At early stage / hours of your new tractor?
Yes, it's been a while since I had the problem, I had under 100 hours on it . . . it just needed the bolts tightened.
/ TYM - T474HC RPM loss problem fixed. #17
Gas, this reminds me of your previous experience years ago with another "off brand" tractor.
Wasn't there quite a few (4-5?) used kubotas in between the 2 major headaches?
I really hope this is fixed now and doesn't turn out like that "red" tractor fiasco. 👍
Yes. I have a bad habit of trying to find deals on used equipment. Then use them to get a bunch of work done on the property, then sell them. See if I can make a small profit or break even. The Kubota’s are the ones with the least amount of problems.
/ TYM - T474HC RPM loss problem fixed. #19
Good to hear your tractor is fixed. Only time will tell though.
Easy to second guess yourself. Sounds like your dealer is on the ball.
/ TYM - T474HC RPM loss problem fixed. #20
It's only been a week since the first post. If it is fixed, that's pretty awesome. Can't wait to hear what the issue was.
