TYM - T474HC RPM loss problem fixed.
   / TYM - T474HC RPM loss problem fixed. #14
Lots of new tractors have Yanmar engines and other parts/stuff from them. So your hand throttle was malfunctioning? At early stage / hours of your new tractor?
Yes, it's been a while since I had the problem, I had under 100 hours on it . . . it just needed the bolts tightened.
   / TYM - T474HC RPM loss problem fixed. #17
Gas, this reminds me of your previous experience years ago with another "off brand" tractor.
Wasn't there quite a few (4-5?) used kubotas in between the 2 major headaches?
I really hope this is fixed now and doesn't turn out like that "red" tractor fiasco. 👍
Yes. I have a bad habit of trying to find deals on used equipment. Then use them to get a bunch of work done on the property, then sell them. See if I can make a small profit or break even. The Kubota’s are the ones with the least amount of problems.
   / TYM - T474HC RPM loss problem fixed. #19
Good to hear your tractor is fixed. Only time will tell though.
Easy to second guess yourself. Sounds like your dealer is on the ball.
   / TYM - T474HC RPM loss problem fixed. #20
It's only been a week since the first post. If it is fixed, that's pretty awesome. Can't wait to hear what the issue was.
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
