TYM - T474HC My next work partner. [ Problems already! ]
   / TYM - T474HC My next work partner. [ Problems already! ] #22
Decided I wanted to get back into a HST transmission Tractor. Went with a new TYM T474 HC…..View attachment 3539959
Had the dealer load the rear tires, add a plug-in block heater, and the 3rd function kit down the loader. Should make for a comfortable, year round work horse.
Who else has one of these or the 494/574?
I bought a 474 in June as well. Currently shopping for oils for my 50hr change. Having trouble finding a hydraulic oil i like locally. Bought the full filter kit from my dealer and found the same kit online for half the price from dealer in Colorado. Shop around before you buy
   / TYM - T474HC My next work partner. [ Problems already! ] #23
The TSC Traveller Premium Tractor fluid works in my 574H (same engine as the 474, but turbo).
   / TYM - T474HC My next work partner. [ Problems already! ] #24
Mobil Delvac THF not available in your area. mboulais?
   / TYM - T474HC My next work partner. [ Problems already! ] #25
I have a 2024 474 w/ cab. 138 hours. No regen thus far. Only issue I've had was a the valve that opens for heat/AC failed and the dealer replaced it. It was dripping red fluid from above the cab onto the floor steering wheel and floor .Said very unusual repair. The heat works well and so does the AC. I'm considering wheel spacers to widen the rear stance 3" on each wheel for more stability. Otherwise a lot of tractor for $$$$.
   / TYM - T474HC My next work partner. [ Problems already! ] #26
Get Brotek spacers, they are the best bang for the $$$, I put 1.5 spacers mostly to make room for chains in the winter. But added 3'' overall.
   / TYM - T474HC My next work partner. [ Problems already! ] #27
Thanks for the heads up on the valve leak. Will watch for it. Spacers will probably affect warranty and will put more load on bearings.
   / TYM - T474HC My next work partner. [ Problems already! ] #28
So far I've not heard of that, and VERY few tractors have hub problems on the rear.
   / TYM - T474HC My next work partner. [ Problems already! ] #30
Some days I wish I had gone a little bigger. Some days I miss having a backhoe. But it’s mowing well and doing light duty loader work well. So far, so good.
I considered a backhoe, but iirc, it was an additional $7k-11k. That's a lot of mini-ex rentals.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
HarbinGer V3 Plus Towable Light Tower (A52377)
HarbinGer V3 Plus...
