MoMatt
I have a 2006 TYM T330 HST with a TL200 Loader.
The 4 way loader joystick leaks from the base of the joystick. I've taken apart the front of the joystick and see 4 O rings on the 2 valves. I'm going to replace those. Can anyone tell what the problem might be if the O rings don't fix it? Should I take the whole valve apart?
I wasn't able to get the hoses off easily. I've tried with a 1" wrench but the hoses don't budge. Any tips?
Here are some pictures:
And here's a video (still uploading / processing at the time of this post, it should be live in 20 minutes or so):
In the video when you hear a load on the engine, I am raising the 3PH with a heavy implement (snowblower). You can see when there's a load on the system, fluid gushes out from the plate at the base of the joystick.
