TYM T25 this thing is amazing!!!
   / TYM T25 this thing is amazing!!! #91
Has anyone compiled a list of acceptable oil, hydrostatic and fuel filter alternatives to the TYM branded ones for the T25? I do plan on using OEM filters, but would like to know of equivalent name brand filters that might be more obtainable in the future.
Kim
   / TYM T25 this thing is amazing!!! #92
Kim
I was just looking that up for my TYM T494 and I just requested this info from TYM. But I did see another TYM owner post this info.
   / TYM T25 this thing is amazing!!! #93
There's a good YouTube video from Rock Hill Farms. His dealer walks through the whole 50 hour service for his T574. Mine is almost due, too.
   / TYM T25 this thing is amazing!!! #94
Does that entire mid-mount PTO business come off?
I could see keeping that there for winter/snow blowing where you're staying on the road, but for most uses I'd have of a tractor like that, that's really low ground clearance.
   / TYM T25 this thing is amazing!!! #95
I watched that video, its very good info! My T494 is basically the same tractor except for the Turbo.
The interesting thing is when the engine oil was drained and the guy mentions the attached backhoe frame with the plate that blocks access to the oil drain plugs and he said the plate/frame would not be there if the owner did not order the backhoe.
I changed my oil yesterday and I also had that plate/frame but I did not order the backhoe. I also notice those two holes on the plate were probably there for access to the drain plugs and if true then that plate was probably installed backwards as is mine. All the oil from both plugs poured onto the top of the plate and then flowed down from the plate on both sides and through the holes which gets messy and a pita to cleanup.
   / TYM T25 this thing is amazing!!! #97
Just wanted to give an awesome tip on a better steering wheel for the tym t25 / rk 25. I have a cab on my t25 and am a larger dude. The stock steering wheel is so low and hit my knees and just doesn't fit right. I put a Ferguson 1720 steering wheel on my t25 and what an upgrade! Its now above my knees and can get in and out of the cab so much better. Its a direct fit no mod needed. Tony needs to get this changed on the new models...
   / TYM T25 this thing is amazing!!! #98
Where did you get this steering wheel?
   / TYM T25 this thing is amazing!!! #99
Been looking hard at this model. It is now tops on my list. This would be my first tractor ever, so I am really doing the research to make sure I know what I am getting into.
Looks like you went a little bigger than the model the OP wrote about. How do you like your TYM Rich?
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
