TYm HST oil
/ TYm HST oil #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
Thinking about going to synthetic on the Mahindra 2810HST, which is essentially a TYM with red makeup on. Has anyone tried synthetic in the tranny and were the results good?
Thanks
/ TYm HST oil #2
Be careful, unless the engine was specifically designed for synthetic oil you may lose your seals, and it may leak badly. Mobile 1 red grease however is a great replacement for lithium or common grease. That you can safely use.
If your smoking check your fuel injectors and pump timing.
Thanks
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
