Comparison TYM 394 VS KIOTI CK4010
   / TYM 394 VS KIOTI CK4010 #31
Why do you thinks it's a no brainer?
TYM has built tractors for a while now for Mahindra first the 10 series and now the 25xx series. From what I have seen the 35 hp and larger TYM built tractors do not have many issues. Mahindra has has some issues with their new Mahindra engine emissions which they are working out the issues. TYM uses the Yanmar engines in their 35-55 hp tractors. I think John Deere still uses the Yanmar engines in some tractors. Also you are getting more tractor for less money. If your dealer is solid and has a good relationship with TYM this is TYM’s biggest issue. TYM is expanding. My local John Deere dealer had his dealership taken from him because he was too small. His family had been a dealer for decades.
   / TYM 394 VS KIOTI CK4010 #32
John Deere uses Yanmar engines in nearly all of their under-50hp tractors and Yanmar used to build quite a few tractors for John Deere.
So almost decision day. Let's pretend both tractor companies are equal as to parts and service. Tractor vs. Tractor. Again I will be bush hogging(6') 20+ acres, log skidding, post hole digging, snow removal, logging road maintenance, and misc stuff around the horse farm and pasture. Let's hear it as I am making my decision very soon.
   / TYM 394 VS KIOTI CK4010 #34
Let's pretend both tractor companies are equal as to parts and service. .
Why "pretend"? I don't think they are equal given Kioti's more entrenched dealer base. Again, I'd buy Kioti of those two brands.
   / TYM 394 VS KIOTI CK4010 #35
You pays your money and you takes your chances...
For the sake of the thread I am looking for a tractor vs tractor comparison, not a company vs company comparison.
   / TYM 394 VS KIOTI CK4010 #38
With all due respect I believe you have made up your mind in favor of TYM. So why continue to ask? It is not possible (in my opinion) to recommend a tractor independent of manufacturer. If that was the case, why exclude junk 3rd world manufacturers?
Just because I believe in the local tym dealer doesn't mean I'm leaning that way. Believe me, I would buy from them in a heartbeat but my kioti dealer i feel is also reliable. When I started this thread I was set in kioti. Just was hoping for.some current owners of either, or those knowledgeable to help in the decision. So again read what.i am using it for and give me some good advice on these 2 rigs other than dealer network or service . Cause either tractor I'm good with that end.
   / TYM 394 VS KIOTI CK4010 #40
Huh? Translate that
It's an idiom meaning that you have several options, and each has advantages and disadvantages. So you pick one, and you put up with the results one way or the other.
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2021 Ford F-150XL (A57148)
2021 Ford F-150XL...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Compressor (A55973)
Compressor (A55973)
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
