TYM 353 HST PTO -- how to dis-engage so it rotates freely ??
   / TYM 353 HST PTO -- how to dis-engage so it rotates freely ?? #1
astro1949
is there a way to disengage the PTO so it will rotate freely ?
353-HST
thanks
bob
   / TYM 353 HST PTO -- how to dis-engage so it rotates freely ?? #2
Most of the new tractors have a hydraulic brake system on them that locks the PTO shaft from turning. It may disengage when the engine stops. Both my LS and B.I.L's New Holland lock the PTO shaft. I have never checked the Kubota B26 to see if it locks as I just use it for a TLB.
   / TYM 353 HST PTO -- how to dis-engage so it rotates freely ?? #3
Make sure the electronic engagement is off and also the PTO lever on the right side of the drivers seat is in the "off" position. It should turn by hand.
did you mean left side for the rear?
ill try it tomorrow
thanks
   / TYM 353 HST PTO -- how to dis-engage so it rotates freely ?? #5
Yes. Sorry - the right side is the mid PTO. The rear is on the left.
thank you ill try it
WOW !! It works !! TURNS FREELY----after asking for 5 years, You solved my problem !! THANK YOU.
the book is of NO Value on this. My dealer closed a few months after i purchased the 353.
bob
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2019 Allmand...
