Buying Advice TYM 264 or Yanmar 424
/ TYM 264 or Yanmar 424 #1
coyotef150
Juniata County Central PA
TYM T 264 1959 Ferguson TO-35
Hi. I am looking for some advice on either a TYM 264 or a Yanmar 424. I will use it mostly for firewood other normal tractor stuff. My property is pretty steep so stability is very important. I was pretty much set on the 424 since I saw them a few years ago ,but not having individual brakes bugged me and they didn't have a diff lock back then either. Last year I drove a 264 and a 424 and I thought the 424 seemed underpowered. It didn't have a lot of power on a hill in the dealer's yard and the hydro whine was pretty loud. However I just saw that Youtube video of a 424 pulling what they said was 30000 lbs. so was I just on one with issues. The 264 seems to have everything a tractor should for a good price. The auto throttle was neat and I liked the quick attach for the bucket.I have 2 Yanmar dealers within 15 miles and the TYM dealer is about 25. To throw another wrench into my decision is the fact that I also like the Kioti CK2610 if I could find one at the right price. I know the 2610 is bigger and I don't want to get too small or too big of a tractor. Right now I use a 1959 Ferguson TO-35 and a Ford 1210 neither have loaders. Any help would be very appreciated.
/ TYM 264 or Yanmar 424 #2
Well, not bashing the tractor in the video at all, but I think a 25 hp SCUT could have pulled that truck and trailer in the video. It wasn't really "pulling" 30,000 pounds. All it was doing was over coming the rolling resistance of the truck and trailer that were sitting on flat ground. Now if they repeated that test after taking all the wheels and tires off of the truck and trailer, well then we'd have something.
What kind of "firewood" work are you going to use it for? And how steep is "pretty steep"?
I know you have to take videos like that with a grain of salt . The one I drove just seemed underpowered. I am not sure of the exact degree of incline of my hill, I Just know that I am sick of standing on the brakes and trying not to slide down the hill on the old Ferguson with no power steering either. My firewood work won't be to serious , some dragging of logs ,some lifting big pieces onto my splitter that I don't want to do by hand.I have a homemade 3 pt winch made from an old Jeep winch that I use on the Ferguson . I don't know if I would or should use that on a compact or subcompact.
/ TYM 264 or Yanmar 424 #4
Both seem like real nice tractors. In that size range you have nothing but real nice choices and a whole lot of makes. I'd go for whatever you felt is just the best quality with the best dealer. Is there a MF dealer in the mix too? Is HST an absolute must have? Brand new only?
I had some hilly land to cut firewood on 50 years ago and ended up using a Yanmar 16hp 6F/2R gear box with H/L. It had a FEL and it didn't have a bit of trouble with pulling power towing surprising large logs with a chain around them. Of course some of that was the regular gear box and how positive it is without any slippage. Like you, I had gotten tired of sliding down the hill on our farm tractor. Leaving the Yanmar in 4wd and lowest of the low range when decending made the difference and also backing down when things were too steep.
But what I was going to say was more important turned out to be the tires & wheels. The tractor wasn't heavy enough to bite in using ag tires, so I swapped them for some wide low turf tires and wheel that could be reversed to make the wheel base a lot wider. That lowered the tractor only about an inch, but the width of wide tire plus reversed rim really made it a lot more stable. The stability made up for the low HP.
I like auto-throttle myself on HST, but HST wouldn't probably be my choice on a small work tractor unless it had more than 2 speeds. I know, lots of people use them and like them. I'm just old-fashioned enough to thing there is still a place for direct drive. Favorite transmission is still a 4x2 powershift. Do they still make that for small tractors?
If any of them offers a standard SSQA type of quick disconnect front bucket I've found that to be very handy. But a total quick disconnect FEL not so much.
rScotty
I am leaning towards brand new just for the warranty and financing.I don't know if MF makes an overgrown subcompact like the 424 or 264 . I too like the manual transmission idea but I don't want to get one and then wish I had the HST. I think the Kioti CKs have a manual transmission option that seems to be 1000-1200 cheaper. I think they are only synchronized on 2nd and reverse? The TYM has the SSQA but the Yanmar is their own pin type design.
I have begun to also think about the Branson 2610 or the 2515 . Anyone have thoughts on them .
/ TYM 264 or Yanmar 424 #7
I looked at the 5520 Branson it seemed a well built machine, sorry didn’t look at any of the smaller units.
/ TYM 264 or Yanmar 424 #8
Both good machines and selling very well, specially the 2515 due to it's larger size, which is nice since you're working on steep hills.
I have a F36RN, which is the European version of the 3515R but a Narrow model because it's sold here as a Vyneard tractor.
Besides being narrower than the US model, I still find it very stable on wheels. I do a lot of mowing on hills and it doesn't even get tipsy. I do have the rear tires filled, which I fully recommend to any tractor.
With the 2515, you get a lifting capacity on the loader of 2200 lbs on a 25HP tractor which is pretty nice to have. You also get a 540 and a 540E/750 on the PTO, that I use all the time.
Thank you guys for the replies. There is a place not far from me that started selling Bransons last year. I may go check them out. That 2515 looks like a lot of tractor for the money.
As you may be able to tell I am a very indecisive person. Did not check out the Bransons yet .I was going to look at the TYM today but they are sold out. Any thoughts on the Workmaster 25 Can't find much info on pricing online.
/ TYM 264 or Yanmar 424 #11
Which Workmaster 25 are you asking about? The 25-S is a sub compact , smaller than the 424. The regular Workmaster 25 is larger and heavier than the 424. Another thing to point out the the entire NH Workmaster series is made by LS tractor, rebadged with a slightly darker blue paint and NH stickers. The loaders are made by a different manufacturer for NH, so they are the major difference.
If you research LS tractors, their pricing is usually easier to find, and usually substantially less than NH.
I am asking about the bigger one. I think it is the same as the LS MT 225. They seem like they are bigger than the TYM 264 which is why I am considering one. The 264 has everything a tractor should that the other subcompacts don't such as the SSQA, individual brakes you can actually use due to no clutch pedal, and the diff lock.I was set on a 424 until I saw the 264.If money were no object I would get a Workmaster 35 or something like it. I have liked blue tractors since I was a little kid but that red TYM has my attention. I don't have any LS dealers close by ,but maybe I will expand my search.
/ TYM 264 or Yanmar 424 #13
Worth it to just take a look. You might be surprised. I was also researching TYM when I was shopping. Unfortunately the closest dealer could not come close to the LS price.
Not sure where you are located. Pricing can vary widely according to region. You could add a general location in your profile, it might help others point you in the right direction.
/ TYM 264 or Yanmar 424 #15
Thanks I added my location. I am in central PA about 50 miles north of Harrisburg.
I grew up / lived in Bucks County, just outside Philadelphia. Moved out here in ‘95, so cannot help with dealers in your area now.....
That"s cool .You are a long way from home now. We are camping this week and I found a NH & Kioti dealer about 1/2 hour from our site . I can take a little break from fishing for tractor shopping, especially blue ones.
/ TYM 264 or Yanmar 424 #17
I really like the Kioti CK2610. I was really hammering the dealer to try and get closer to the LS price, but he was still $2500 more than LS.
I am extremely happy with my LS XG3025 (same as the MT225E) and LS in general. This is my second LS, I was just as happy with my first one.
Good luck with your search. Sit on them, drive them, get the features you want / need.
They didn't have the Workmaster 25 or the 2610 in stock. Got some pricing and checked out a Workmaster 35 and really liked it but I don't think I can afford that one. I will probably go look at the TYM 264 again when they get some more in stock.
/ TYM 264 or Yanmar 424 #19
There is an LS dealer up by Bloomsburg PA. To find them on the dealer located type in the zip code for Bloomsburg on the LS dealer search.
I think I know where that is .I didn't call them or make it up that way yet.That is a little farther than I would like to be from a dealer but I would definitely consider it.
