TYM 1003 gear shifting
   / TYM 1003 gear shifting #1
sk211612
Estonia
TYM 1003
Hello
Can anybody advise.
I have TYM 1003 and when I switch gears from fourth to third, then hear a crackling sound.:confused:
It should not be, because it should be a synchronized gear box.
Does anyone know what to think?
   / TYM 1003 gear shifting #2
Greetings!
I have a few questions in order to help with your situation.
1) Does the problem occur when you are sitting still or when you are moving? Or both?
2) Does it occur in all gear ranges, (High, Medium, Low)?
3) Is there any particular speed it intensifies at? (Turtle - Rabbit)
Thank you for being a valuable TYM customer, I'd be glad to assist in anyway possible!
The probleem occur only moving in high range when i switch gear from fourth to third.
   / TYM 1003 gear shifting #4
After you are in gear, is it still making noise?
It sounds as if it's a synchronizer issue if it's only occurring during gear switch.
I would recommend visiting your local dealership for assistance. The synchronizer is covered within your first 3 years/3000 hours of warranty assistance.
As a reference, the part number is 14482092100 for the synchronizer assembly.
Please feel free to let me know if you're still having issues. I'd be glad to be of assistance.
crackling sound occurs only during gearswitch. Tractor is brand new 8 working hour.
Dealership is aware of the problem. Maintenance man has adjust the clutch but it did not solvethe problem.
Let's see what happens when a little bit more work to be done. Estonian dealer gives 2 years/2000hours of warranty.
   / TYM 1003 gear shifting #6
I'm associated with TYM-USA, however, according to the issue from my perspective. It sounds as if the sychronizer needs inspecting. It could possibly need replacing or something as simple as replacing a ring.
Gear shifting is better when oil is warm.
if the gear oil is cold it is hard to switch gear. I will have to keep the lever under pressure to switch the gear.
Second question: Is it possible to install TYM 1003 trailer brakes, air or oil brakes.
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
1999 Toyota Avalon Sedan (A50324)
1999 Toyota Avalon...
