TY395 Cylinder head torque
/ TY395 Cylinder head torque #1
HankC
Mass.
Getting a bit warmer here and I'm planning to do some scheduled maintainance. I will be re-torquing the cylinder head as well as setting the valve clearance. A question for anybody out there who may have a similar engine (30 HP), would you know what the torque values are for the cylinder head bolts and the rocker-arm bolts. My manual specs out the cylinder head values at 89-100 ft/lbs (120 - 135 N-M). Is this correct?
There are no specs for the rocker arm bolts /forums/images/graemlins/confused.gif
All help and comments appreciated /forums/images/graemlins/wink.gif
HankC
Joe,
Thanks a lot, that surely helped. Larry did a wonderful job with his photos.
HankC
/ TY395 Cylinder head torque #4
Personally I would not exceed 120 ft lbs, I think 155 is too much over factory spec. we use 100 in our shop.
Thanks Chip,
I was going to stick with specs which call for a max of 100 ft-lbs.
Would you know what you use for the rocker arms torque values?
HankC
/ TY395 Cylinder head torque #6
I have not seen a spec on those, you can use the standard for the bolt size, remembering you are in cast iron, not steel, We just go by feel, tight but not too much.
John Deere 750C Dozer (A66285)
John Deere 750C...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2012 International 4300 Reefer Truck (A63689)
2012 International...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
