TY395 Cylinder head torque
/ TY395 Cylinder head torque #1
HankC
Mass.
Getting a bit warmer here and I'm planning to do some scheduled maintainance. I will be re-torquing the cylinder head as well as setting the valve clearance. A question for anybody out there who may have a similar engine (30 HP), would you know what the torque values are for the cylinder head bolts and the rocker-arm bolts. My manual specs out the cylinder head values at 89-100 ft/lbs (120 - 135 N-M). Is this correct?
There are no specs for the rocker arm bolts /forums/images/graemlins/confused.gif
All help and comments appreciated /forums/images/graemlins/wink.gif
HankC
Joe,
Thanks a lot, that surely helped. Larry did a wonderful job with his photos.
HankC
/ TY395 Cylinder head torque #4
Personally I would not exceed 120 ft lbs, I think 155 is too much over factory spec. we use 100 in our shop.
Thanks Chip,
I was going to stick with specs which call for a max of 100 ft-lbs.
Would you know what you use for the rocker arms torque values?
HankC
/ TY395 Cylinder head torque #6
I have not seen a spec on those, you can use the standard for the bolt size, remembering you are in cast iron, not steel, We just go by feel, tight but not too much.
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
MAXILATOR SQUARE BALE ACCUMULATOR GRAPPLE (A64277)
MAXILATOR SQUARE...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
