TY395 Cylinder head torque
   / TY395 Cylinder head torque #1
HankC
Bronze Member
Mass.
Getting a bit warmer here and I'm planning to do some scheduled maintainance. I will be re-torquing the cylinder head as well as setting the valve clearance. A question for anybody out there who may have a similar engine (30 HP), would you know what the torque values are for the cylinder head bolts and the rocker-arm bolts. My manual specs out the cylinder head values at 89-100 ft/lbs (120 - 135 N-M). Is this correct?
There are no specs for the rocker arm bolts /forums/images/graemlins/confused.gif
All help and comments appreciated /forums/images/graemlins/wink.gif
HankC
Joe,
Thanks a lot, that surely helped. Larry did a wonderful job with his photos.
HankC
   / TY395 Cylinder head torque #4
Personally I would not exceed 120 ft lbs, I think 155 is too much over factory spec. we use 100 in our shop.
Thanks Chip,
I was going to stick with specs which call for a max of 100 ft-lbs.
Would you know what you use for the rocker arms torque values?
HankC
   / TY395 Cylinder head torque #6
I have not seen a spec on those, you can use the standard for the bolt size, remembering you are in cast iron, not steel, We just go by feel, tight but not too much.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2011 Kubota ZG222 (A50123)
2011 Kubota ZG222...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
