Tx Jim need your expertise
   / Tx Jim need your expertise #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I am looking to put a second set of rear hydraulic remotes on my 2011 JD 5093E Limited and have been looking up parts numbers and have came up with field installation kit part# LBV25790 which some drawings show exactly what I need which are the 2 rear quick attach remotes , the 2 hydraulic hoses and lastly the second handle that operates that set of remotes, other drawings show 2 handles and or other parts. My question is this, is this a good part# for the second set of remotes? Any help would be appreciated. Thanks. Charlie.
   / Tx Jim need your expertise #2
I lost my ability to log in under Tx Jim so I had to change my handle to JimB77. There are members of this forum that are a lot more knowledgeable about 5093E than I am. It appears LBV25790 in 5093E parts catalog is a "complete goods #" of which I have no access to correct info but I can't determine if 2nd control valve is included in LBV25790.
   / Tx Jim need your expertise #3
I would ask the service department of your local JD dealer to print out the instructions for LBV28790. It will include a parts list.
Complete Good are bought through sales not parts. Check with sales for a price.
   / Tx Jim need your expertise #4
Why can this not be a fixable problem. We need Tx Jim back under his real forum name.
   / Tx Jim need your expertise #5
This kit should be all you need to connect the lever and cable to the existing valve spool on your tractor. It also includes the 2 hoses, couplers and coupler bracket. Here are the instructions.
  • R270824_19.pdf
   / Tx Jim need your expertise #6
Thanks for your concern. Several months back after being automatically logged out I was unable to log in under Tx Jim handle I changed my handle to Jim in Tx. I sent several PM's or emails to the button below "contact Us" about my inability to log in with no responses. After posting under the handle of Jim in Tx for a while I was contacted via a PM by a site moderator inquiring if I desired to change back to Tx Jim & combining my posts from while under the Jim in Tx handle. I stated that would be fine. I was emailed a temporary password that I couldn't get to work even after several attempts. I sent PM's with no replies. Then the Jim in TX was disabled & my "saved password" wouldn't allow signing in. So I chose a 3rd handle & I'm afraid to change my handle again for fear of being blocked from this site.
I sent another email to contact@tractorbynet.com
Thank you very much, that is exactly what I was looking for and what I needed, also because several other people were telling me that I needed another valve spool , and i knew that this kit didn't come with one so I wanted to make sure that I was getting everything that I needed to add the second set of remotes. Charlie.
Sometimes people make things more difficult than it needs to be , there surely is an easy fix to this problem, it's usually a matter of getting a person who is actually interested in helping you on the task.
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
2018 JAGUAR XE (A56859)
2018 JAGUAR XE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
