Tx Jim need your expertise
   / Tx Jim need your expertise #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I am looking to put a second set of rear hydraulic remotes on my 2011 JD 5093E Limited and have been looking up parts numbers and have came up with field installation kit part# LBV25790 which some drawings show exactly what I need which are the 2 rear quick attach remotes , the 2 hydraulic hoses and lastly the second handle that operates that set of remotes, other drawings show 2 handles and or other parts. My question is this, is this a good part# for the second set of remotes? Any help would be appreciated. Thanks. Charlie.
   / Tx Jim need your expertise #2
I lost my ability to log in under Tx Jim so I had to change my handle to JimB77. There are members of this forum that are a lot more knowledgeable about 5093E than I am. It appears LBV25790 in 5093E parts catalog is a "complete goods #" of which I have no access to correct info but I can't determine if 2nd control valve is included in LBV25790.
   / Tx Jim need your expertise #3
I would ask the service department of your local JD dealer to print out the instructions for LBV28790. It will include a parts list.
Complete Good are bought through sales not parts. Check with sales for a price.
   / Tx Jim need your expertise #4
Why can this not be a fixable problem. We need Tx Jim back under his real forum name.
   / Tx Jim need your expertise #5
This kit should be all you need to connect the lever and cable to the existing valve spool on your tractor. It also includes the 2 hoses, couplers and coupler bracket. Here are the instructions.
  • R270824_19.pdf
   / Tx Jim need your expertise #6
Thanks for your concern. Several months back after being automatically logged out I was unable to log in under Tx Jim handle I changed my handle to Jim in Tx. I sent several PM's or emails to the button below "contact Us" about my inability to log in with no responses. After posting under the handle of Jim in Tx for a while I was contacted via a PM by a site moderator inquiring if I desired to change back to Tx Jim & combining my posts from while under the Jim in Tx handle. I stated that would be fine. I was emailed a temporary password that I couldn't get to work even after several attempts. I sent PM's with no replies. Then the Jim in TX was disabled & my "saved password" wouldn't allow signing in. So I chose a 3rd handle & I'm afraid to change my handle again for fear of being blocked from this site.
I sent another email to contact@tractorbynet.com
Thank you very much, that is exactly what I was looking for and what I needed, also because several other people were telling me that I needed another valve spool , and i knew that this kit didn't come with one so I wanted to make sure that I was getting everything that I needed to add the second set of remotes. Charlie.
Sometimes people make things more difficult than it needs to be , there surely is an easy fix to this problem, it's usually a matter of getting a person who is actually interested in helping you on the task.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
