Ballast Two valve stems per tire
   / Two valve stems per tire #11
Why would you use a valve stem? Just drill and tap a 1/8" hole across from the valve stem, fill to the hole in the top of the rim and put the pipe plug in it. CJ
Might not be enough metal to cut threads in.
   / Two valve stems per tire #12
   / Two valve stems per tire #13
If that's the case then the rims are rotted out. CJ
   / Two valve stems per tire #14
How thick do you think the rim are ??
   / Two valve stems per tire #15
You can probably check the thickness of the rim's metal by simply looking at the edge where the tire seats... there's a lip on all the rims I have looked at. Rear tires probably only are running 10-12 lbs of pressure, and the plug is a small area, so even 1/8th inch of rim should be enough to hold a protected plug.
   / Two valve stems per tire #16
Double the valves = double the trouble. Every time you go into a pile of brush you stand the chance of bending or breaking them off.
Filler valves have a air relief in them so as you pump liquid in, the air will purge out at the same time. When liquid comes out of the relief the tire is full. Of course the valve stem is steel and has a larger diameter than the standard stem. My rears have larger stems than the front to accept these filling valves.
   / Two valve stems per tire #19
If/when the time comes and I have my tires apart, I will weld a 1-1/2" x 2" nipple to the rim over the valve stem and put a pipe cap on it. learned that on most if not all of the forestry equipment that had tires on it had protectors for the stems. Cheap and easy to do. CJ
   / Two valve stems per tire #20
1,000 upon 1,000 of 12v on demand pumps out there. every 4 wheeler utv/ atv, to pull behind sprays for riding lawn mowers. have these 12v on demand pumps. so when you pull trigger on the wand pump turns on and it sprays. let off trigger, pump turns off and no water is sprayed.
the tire filler tool. close valve on unit = 12v on demand pump shuts off. undo air bleed valve. wait a few seconds. close bleed valve. open fluid valve. pump turns on automatically.
turning the pump off. while air is being bleed = keeping the fluid from coming and spraying all over, when you bleed the air out.
i have seen one better "fluid filler tool" out there. it might be common thing folks are buying now.
the standard remove the core of the tire nipple. then screw in the fluid tool. the fluid tool has a longer pipe that sticks up into the tire to bleed out air. and then around this longer tube. fluid comes in. ""kinda 1 pipe inside of another pipe thing"". so you can fill tire with fluid at same time you bleed the air out. going through the same tire nipple. and you just run the bleeder air hose back to container you are pumping from. so end of hose hangs above the fluid surface. so you pretty much attach and forget for a few minutes. and never needing to bleed air / turn on/off pump.
p.s. i think there was an on/off valve for the fluid hose. so you could back the off the fluid. and give the air a chance to escape the closer tire got to being 75% or so filled.
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
3079 (A56857)
3079 (A56857)
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
JOHN DEERE HAY CUTTER (A58214)
JOHN DEERE HAY...
Massey Ferguson 1759 (A57148)
Massey Ferguson...
