Two Thumbs up on B2320 DTN First Day
   / Two Thumbs up on B2320 DTN First Day
Maybe everyone is confusing specs between the 2320 DT (gear drive) and the 2320 DTN (gear drive narrow).
The DT has quarter inching and available with an FEL.
The DTN (narrow) is not available with an FEL but has position control.
Ah thanks I didn't realize what the N was for, thanks.
I have a DT not a DTN, that explains a lot of confusion.
   / Two Thumbs up on B2320 DTN First Day #32
Hello, could you measure for me the distance from the ground to the chair (measured to the surface where you're bottom is on) I need it to determine if I can drive below some beams I have on my field.
thnxs,
Adryan
2024 Bobcat T770 (A57148)
2024 Bobcat T770...
Philadelphia Tram Rail (PTR) 60 inch Cardboard Recycling Baler (A59213)
Philadelphia Tram...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
CAT D6T LGP DOZER (A58216)
CAT D6T LGP DOZER...
