3-Point Hitch Two landscaping questions using my tractor
   / Two landscaping questions using my tractor #21
Thanks for the quick reply and one more thing is my neighbour/buddy has a box blade and a roller as well so I have acess to them. I am thinking on 6" deep to make strong enough for the gravel stones or some foundation.
But thanks so much for answering so fast.
Ganesh
Have fun with the project.
   / Two landscaping questions using my tractor #22
I have to agree with going down at least 8" for the pavement. You need a good base to start with. Then you will need at least 4" to 6" of concrete to handle the weight. The last thing you want to do is pour the slab only to crack it into pieces when something heavy is on it.
   / Two landscaping questions using my tractor #23
I thought 18" is by rules for the wires, I have to check and as far as the rear weights I have filled tires with fluid and my dealer said I dont need any weights at all for lifting with my loader. Is that now true?
Ganesh
Here in Canada we do have rules for burying wire. To put it simply they can be 2 diferent depths. 18" for areas where there isn't going to be any vehicles (tractors included), or 3' where there is going to be vehicles.
There is one execption to this rule. If there is some sort of protection over the wires they can be shallower. Protection means something like you're paving over the area where the wires are run.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
