Two-claw log tongs any good?
   / Two-claw log tongs any good? #1
sushan
John Deere
Anyone using the 2-claw type? I mostly lift smaller logs for milling and splitting.
I noticed Amazon and GARVEE both have 2-claw log lifting tongs — wondering if they stay steady or tend to twist under load.
   / Two-claw log tongs any good? #2
It all depends on the size and shape of the log, how you grab it, how good of a bite the tong's teeth get, etc. I use one similar to what you have shown and it's been ok, but not fool proof.
   / Two-claw log tongs any good? #3
I use these
For LIFTING big rounds and logs with the FEL while working up firewood.
They are no good at all for dragging logs with only a chain, as when the log rolls and the tongs go under or sidewise, the tongs will get bent or twisted.
If one had some sort of boom to lift the log up behind the tractor, the tongs are faster than a choker to hook up.
   / Two-claw log tongs any good? #4
I have the old style and happy with it...better than trying get chain wrap round log.
   / Two-claw log tongs any good? #5
I use one for dragging and lifting long logs onto blocks to make it easier to cut to firewood length before splitting. It works good for me.
   / Two-claw log tongs any good? #6
Get the ones with 4 claws.
I got the 2 claw ones first, but they were useless. Kept twisting and sliding and logs kept slipping out.
Got the cheap vevor with 4 claws from Amazon. It's 100 times better and more stable, and I dont lose logs now.
I can pick up logs without having to get off the tractor with them too.
2 claw sits now in the garage. Not using it at all
   / Two-claw log tongs any good? #7
When I use the tongs for lifting, I make sure to grab onto the round or log ABOVE center. (not like the image above with the tong hooks UNDER the log.)
By lifting from above center, the work will not try to roll out on it's own.
Same with dragging when it must be done. I try to figure how the log will ride, and then set the tong spikes "above center".
Turning corners can upset the tongs when the log changes orientation however.
   / Two-claw log tongs any good? #8
2 claws are good for dragging. For lifting I prefer 4 claws. In either case you have to get off the tractor to release.
   / Two-claw log tongs any good? #9
Tongs are just another implement in the toolbox. Best for dragging. Don't count on them overhead. Don't leave the choker at home though. They work fine on right size logs, not at all if the log is too small or too large. Bottom line - don't spend too much money on tongs, but you'll be glad to have them from time to time.
   / Two-claw log tongs any good? #10
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
Informational Lot - Financing (A56435)
Informational Lot...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2015 Komatsu PC 210 LC (A53317)
2015 Komatsu PC...
10 ft Shipping Container (A55973)
10 ft Shipping...
2006 BOBCAT T190 SKID STEER (A52707)
2006 BOBCAT T190...
