Tushogg Video
/ Tushogg Video #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
A friend sent me the link to this website. It has a hydro axe and an ASV clearing some woods. It made me think of you guys and your discussion of the different heads and machines.
The video is about 4 minutes long and allot of fun to watch.
Eddie
Tushogg Means Tough
/ Tushogg Video #2
Hi Eddie,
Wow that thing is really quite impressive ! Thanks for the video !
Guess it makes a case for hydro ;)
/ Tushogg Video #3
I noticed that the cutter head is not as wide as the ASV therefore could that mean more track issues? I would think you would want to cut a path at least as wide as the widest width as the equipment you are using.
/ Tushogg Video #4
Remeber that. That is a major factor in track life. That's why I like my 73" wide cut so much. I've also heard the tushogg is even heavier than my timberax. Too heavy!!! Also heard it leaves very large shreads .
/ Tushogg Video #5
I called that company...the smallest one they make requires at least 70 HP, weighs 2400# and cost $24,000. WOW!
/ Tushogg Video #6
It's not really a big problem if the machine is offset to either side. Drawback is that you'll allways have to open up a brush from either left or right side, depending on to which side the machine is off center.
For the 9000 model they mention this:
"Offset cut allows for tire protection and close-in work"
/ Tushogg Video #7
I'm not sure it's a BIG issue. Many manufactures make heads that have less than 69" cut width.
