Oil & Fuel turn up fuel pump?
/ turn up fuel pump? #1
john kelley
How can i turn up the fuel pump on my massey furgeson 231 tractor?
/ turn up fuel pump? #5
I'd have to look at one again, but, I belive there is an oval plate w/ two scres on the side of the pump. Remove the cover & the fuel screw is behind it. I would check with someone who really knows about it as it wouldn't take much of a hp % gain to break stuff.
/ turn up fuel pump? #6
Did you turn up the fuel?
/ turn up fuel pump? #7
Increasing fuel flow by seat-of-pants is a good way to burn valves and seats. Valve material begins to soften at 1,350°F, so a pyrometer is needed in the exhaust manifold.
Seen these kids with a diesel pickup "rolling coal"? That is unburned fuel, part of that unburned fuel coats the cylinder walls and winds up in the crankcase, requiring more frequent oil changes.
If you want more HP buy a bigger tractor, built to handle the HP.
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
John Deere Mirror and Light Kit (A63116)
John Deere Mirror...
TEREX LIGHT TOWER (A63569)
TEREX LIGHT TOWER...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
