Oil & Fuel turn up fuel pump?
   / turn up fuel pump? #1
john kelley
How can i turn up the fuel pump on my massey furgeson 231 tractor?
i need to turn up the outflow
mcnitt said:
Do you mean increase the pressure or outflow?
yes. i nedd to turn up the outflow
   / turn up fuel pump? #5
I'd have to look at one again, but, I belive there is an oval plate w/ two scres on the side of the pump. Remove the cover & the fuel screw is behind it. I would check with someone who really knows about it as it wouldn't take much of a hp % gain to break stuff.
   / turn up fuel pump? #6
Did you turn up the fuel?
   / turn up fuel pump? #7
Increasing fuel flow by seat-of-pants is a good way to burn valves and seats. Valve material begins to soften at 1,350°F, so a pyrometer is needed in the exhaust manifold.
Seen these kids with a diesel pickup "rolling coal"? That is unburned fuel, part of that unburned fuel coats the cylinder walls and winds up in the crankcase, requiring more frequent oil changes.
If you want more HP buy a bigger tractor, built to handle the HP.
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Kubota BX2230D (A47384)
Kubota BX2230D...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
