Turn Signals on 2010D
/ Turn Signals on 2010D #1
nuvz
Laramie, WY
Yanmar 2010D
I know this isn't a huge problem, but it iritates me anyway. What I am talking about is the turn signal switch. You move it left & the right light comes on & vice-versa. What' up with that?? It just seems odd. Also, there is no hazard flasher on this model. Any simpleway to rectify this?
/ Turn Signals on 2010D #2
Sounds like you need to switch the wires (or just sit backwards).
/ Turn Signals on 2010D #3
It's not really backwards. If you'll notice the top of the switch has a small point on it and the bottom of the switch just has a lot of overhang. I thought the same thing so I switched my wires.
Eugene
/ Turn Signals on 2010D #4
<font color="red"> Also, there is no hazard flasher on this model. Any simpleway to rectify this? </font>
On my 1610D there are 2 green wires leaving the switch, one going to each light. I shorted the two toghther by the switch and now I can turn the switch either way and I have hazard flashers.
Rich
/ Turn Signals on 2010D #5
I replaced mine with amber strobes. Tied the 2 together since I don't need turn signals. Turn the switch either way and the strobes start.
Thanks to all! I will simply shrt the wires and be done with it!!
/ Turn Signals on 2010D #7
I tied mine in with the head lights as I have no need for turn signals either. Now they act as running lights.
/ Turn Signals on 2010D #8
Not wanting to start a new thread I did a search on this subject and it is exactly what I am dealing with. I wanted to make my turn signals into hazards so I wired them together and they did work but are noticeably weaker. Can I put a larger flasher in the circuit to make them brighter and longer flash? Right now they are weak and a real short flash.
/ Turn Signals on 2010D #9
could be the flasher. I've replaced mine a couple times
/ Turn Signals on 2010D #10
Yeah I'm gonna try and replace the flasher, any idea on part number/type? Can you pick one up at local auto parts store?
/ Turn Signals on 2010D #11
I think there is a better flasher module available for variable loads such as a truck that sometimes has a trailer. This second one will flash consistently regardless of load. An auto parts counterman should be able to find what you need.
/ Turn Signals on 2010D #12
I installed small switch on jump wire and now when the switch is on I have hazards and when is off I have a turn signal. Love it !!!! :D
/ Turn Signals on 2010D #13
Just got done with that job. On mine it turned out to be the ground. You say one light is briter than the other ?? With a ohm meter look at the ground to the light fixture base on both sides. Should be a 0 ohms. Another way to test without a meter is to touch a wire from the base of each fixture to a ground on the engine, if it works properly with the wires just touching the base of each fixture, you got a ground problem. You see more of this in tractors than cars, you are always in the dirt. Turned out the joints between the pannels on the fenders had lost their ground. If this doesn't work, then you have a wire, switch, or fuse problem. Note here that I have a VN recon. I've noticed that there are many joints in the wireing harness that are just wraped together with tape over the joint. Over time I've gone through and soldered every joint or added a butt splice. Made the whole setup more reliable. I'm another one that took the turn signals and jumpered the wires together, turned them into flashers, don't think there is a need for turn sig in the U.S.
Chris
/ Turn Signals on 2010D #14
Sorry been out of the loop for a few days so just checking back in this morning. I'm going to add some guages to the tractor so when I'm at the auto parts store I'll check into the flasher. Also, I'll check the ground but before I tied the two together both lights blinked bright and long but as soon as they were paired up they got weak so it led me to believe it was the flasher. I seem to recall a buddy of mine had one for his pickup given to him by the dealer for towing.
/ Turn Signals on 2010D #15
As a rule of thumb if they flash dim, it is a wiring issue. If they flash fast, it is an economy flasher issue (and needs a heavy duty one).
You need a hd flasher. They should be bright again once they are flashing at the normal rate.
/ Turn Signals on 2010D #16
I did the tie wires together so I have hazards also but one time later I had a fender that wasn't grounded very well and found one lite was intermittent. Oh any flasher should work you are only dealing with 2 bulbs Id say a standard one would be ok just being new is probably the fix. fwtw
I took a couple star washers and installed them on one of the fender to floorboard bolts and its been good ever since. hth
/ Turn Signals on 2010D #17
funny:laughing: that everyone mentions turn signals. I have always had hazards. Maybe they were wired as hazards b-4 I got it
/ Turn Signals on 2010D #18
I should have done it years ago, funny, one time I was helping a buddy bush hog some of his fathers farm and to get from one field to another we had to drive down the hardball so I put my turn signal on (still no traffic) but wondered why they didn;t have hazards to begin with.
/ Turn Signals on 2010D #19
I thought that was the dumbest thing I ever saw when I got my tractor I guess in Japan in the rice paddy's they have a real traffic problem? :laughing:
Mayrath 30' Auger (A66285)
Mayrath 30' Auger...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Straw Mulcher (A65579)
