Turn PTO by hand
   / Turn PTO by hand #1
bacononeactual
Bronze Member
Michigan
JD 770; LS G3038H
On my gear tractor I can turn my PTO shaft by hand (with engine off ) to line up spline with implement shaft. Can't do that on my g3038h, even with tractor in neutral. Is this typical on hydro tractors?
   / Turn PTO by hand #2
I suspect the difference is that your LS PTO is electrically actuated where your gear tractor has clutch actuated PTO.
Sent from my iPad using TractorByNet
   / Turn PTO by hand #3
My gear LS does the same thing.
Eugene
   / Turn PTO by hand #4
It's what is called indexing, or getting a greasy hand. A very handy thing to be able to do. Some PTOs even have a brake in which case I suspect you would not be able to turn it.
   / Turn PTO by hand
Correct, it is electrically actuated. I guess the answer is that there is no way to make the PTO shaft turn in this case. It's just a pain to have to turn the implement drive on some implements to match.
   / Turn PTO by hand #6
A pain to be sure. My mower is so old there is enough slack in the gears and shaft that I could "probably" make it work- no on second thought it is so old it uses a shear pin at the PTO instead of the new kind with the spring lock. The back hoe, yes you can turn it by hand. The tiller- no way as it is new and there is no play at all. What does the owner's manual say?
   / Turn PTO by hand #7
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
POWER UNIT (A51243)
POWER UNIT (A51243)
2017 Case CX130D Excavator (RIDE AND DRIVE) (A50774)
2017 Case CX130D...
Airman (A50322)
Airman (A50322)
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
