Turfcat 628 won't start when warm
/ Turfcat 628 won't start when warm #1
martygerkin
Turfcat 628
Hello,
I picked up a used Turfcat 628 with a Kubota diesel motor. Low hours, very clean, well maintained.
Today I experienced that it would start when cool, but after running it for a period of time, I could not get it to restart for about 10-15 minutes if I had to turn off the motor... Almost like it had to cool down.
The battery is good. The starter is cycling. It just won't fire up until it cools down.
The temperature gauge was showing around mid-point on the dial.
Rad looks clean. I'm not sure if it's a temperature/sensor issue or a connection issue.
Any thoughts or experience from anyone?
Thanks.
/ Turfcat 628 won't start when warm #2
Hello,
Thanks.
Try starting the engine with the gas cap loosened or off and see if that helps. If it starts then the problem is likely the fuel tank vent. Just one place to start the diagnosis.
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
Komatsu PC200 Excavator (A60352)
Komatsu PC200...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2008 TRAILMASTER 34 GOOSENECK (A60736)
2008 TRAILMASTER...
