Turfcat 628 won't start when warm
/ Turfcat 628 won't start when warm #1
martygerkin
Turfcat 628
Hello,
I picked up a used Turfcat 628 with a Kubota diesel motor. Low hours, very clean, well maintained.
Today I experienced that it would start when cool, but after running it for a period of time, I could not get it to restart for about 10-15 minutes if I had to turn off the motor... Almost like it had to cool down.
The battery is good. The starter is cycling. It just won't fire up until it cools down.
The temperature gauge was showing around mid-point on the dial.
Rad looks clean. I'm not sure if it's a temperature/sensor issue or a connection issue.
Any thoughts or experience from anyone?
Thanks.
/ Turfcat 628 won't start when warm #2
Hello,
Thanks.
Try starting the engine with the gas cap loosened or off and see if that helps. If it starts then the problem is likely the fuel tank vent. Just one place to start the diagnosis.
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2017 Dodge Charger Sedan (A64557)
2017 Dodge Charger...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
YALE FORKLIFT (A63291)
